Since German Castrol is gone.... (IT'S NOT!!)
Mac, that is the stuff they carry. They also stock the black bottle. Try a local Carquest though, I used to buy cases of the 10-30 VR1 grey bottle from them and it was very cheap. Then they went and closed down. If all else fails you can snag a case online or maybe order through a local speed shop.
I'll say at Walmart they do have the best price on German Castrol 0W-40. While you're there, the best filter they carry is the Fram Ultra which is a high end synthetic filter, certainly better than the Purolator Classic.
But the price is typically in the range that it's cheaper to buy the 5 qt plus good filter deal at the parts store if someone is running that special. I do usually pick up an extra 5qt jug from there to add the extra qt at each change plus top off between changes.
https://www.fcpeuro.com/products/0w-...FQiJaQodCuIHxg
It's more likely to be stocked in higher class areas which would have a lot of European cars from what I've seen.
I didn't have an oil pressure change when I went from 0w30 GC to 0w40GC. The 0w30 was known for being a thicker 30w than normal so it could be the same oil just with a rating to reflect that?
I dunno, I'm not an oil expert but I know my car has lower pressure with other 40w oils and this stuff is cheap enough local that I just switched back to running it exclusively.
