balancer pulley install
Old Nov 10, 2014 | 05:14 PM
laurentj23's Avatar
Default balancer pulley install
Hey guys,
is this normal? It seems like the top has more space in between the block than the bottom? I used the crank installer tool to install it, and i tried to remove it again with crank pulley removal tool but it's so damn tight that i couldn't even remove the pulley.
Any idears?
Attached Thumbnails balancer pulley install-img_0081.jpg   balancer pulley install-img_0082.jpg   balancer pulley install-img_0083.jpg
Old Nov 10, 2014 | 05:50 PM
03Sssnake's Avatar
Kind of looks like your crank seal on the timing cover is not seated correctly?
Old Nov 10, 2014 | 08:45 PM
laurentj23's Avatar
That's what i found out. I think i fixed the issue. I use a extension and put it in between the seals and the pulley and gently tapped in. I still unable to take the pulley off though. I used the arp flywheel bolts and a pry bar to hold it in and when i crank it, the pulley turn but didn't wanna come lose. Any suggestions?I don't think my power tool has enough psi to get it off.
Old Nov 10, 2014 | 11:07 PM
03Sssnake's Avatar
I had to use the blue wrench (mapp gas torch) on the hub. With puller and tension on it, use a mapp gas torch around the center section|hub for a minute or two. This should get it good and hot, but do NOT get it depths of hell red hot. Should slide right off after you warm it up.
Old Nov 11, 2014 | 01:02 PM
laurentj23's Avatar
Don't it have a rubber thing inside the hub. I heard its a bad idea heating it up since that will melt the rubber. I might be wrong. But since you've done it, I might try it sir.
Thanks
Old Nov 11, 2014 | 02:17 PM
03Sssnake's Avatar
I don't usually do it, never had to on my previous cars, but my 99 gave me hell during my last cam swap. Whose pulley is that? Looks like an older ASP or Powerbond. Do you still have the crank bolt in there, just turned out 3-4 turns? You just heat up the center|hub section, not the entire pulley and only for a minute or two tops, just get it a little heat in it.
Old Nov 12, 2014 | 08:29 AM
laurentj23's Avatar
It is a used asp pulley that I bought from someone on here. I'll try that method and see. So do you leave the bolt in when you heat it up or out?
Old Nov 12, 2014 | 08:56 AM
03Sssnake's Avatar
leave the bolt in, turned out 3-4 thread with the 3-jaw puller still on w/ tension on the pulley
Old Nov 15, 2014 | 07:43 AM
laurentj23's Avatar
Dude I managed to get it off finally. I have to end up getting a slide hammer and tap the crap out of it. That balanced is trashed.
Old Nov 15, 2014 | 09:29 AM
ls6jay's Avatar
Buy a ati. Spend more, save bearings.
Old Nov 15, 2014 | 09:31 AM
laurentj23's Avatar
I was thinking of getting texas speed kit.
Old Nov 16, 2014 | 03:27 PM
Project GatTagO's Avatar
Hopefully you didn't hammer the **** out of your thrust bearing.
Andrew
Old Nov 17, 2014 | 08:52 AM
laurentj23's Avatar
Andrew
I hope so to. Is there a way to check? I have to spent at least 5 mins heating the hub out before tapping it with a hammer
Old Nov 18, 2014 | 10:10 PM
soundengineer's Avatar
you are using the puller incorrectly...you will never get it off using it like you have pictured
the puller goes inside on the three small flat spots on the pulley
NOT on the outside of the pulley like you have it on that picture..
if you dont have flat sopts on the inside of your pulley
it takes a 3 bolt puller...
Old Nov 19, 2014 | 08:13 AM
laurentj23's Avatar
There is no spots inside the pulley for asp. Tried the other ones. All the bolts that threaded to the pulley ended up break or bent.
Old Nov 19, 2014 | 05:36 PM
JRENIGAR's Avatar
Use a dial indicator to measure the crank thrust clearance. If its out of spec then you will need a new thrust bearing at a minimum.
By having such a small base sized puller the arms weren't parallel with the outer belt grooves from front to back. This probably multiplied the force necessary to remove the pulley by 10. The arms where they attach to the puller base should have been spaced as far apart as the pulley is in diameter for the pull to be a correct 1:1 ratio.
Old Nov 19, 2014 | 07:01 PM
if the bolts bend, then you never had the tool mounted properly
if they break, its because you didnt use a grade 8 bolt
we pull 4-5 balancers off per month and never have any issues....
the tool you show in the picture will never work the way you have it...just cant get enough torque to pull on the pulley, its all wasted going inwards from the extreme angle
you could try a Large 8" or 9" 3 jaw puller, it would give you the leverage you need
but the 3 bolt style works 100% of the time for us when it doesnt have the 3 tabs inside.
Old Nov 20, 2014 | 12:37 PM
laurentj23's Avatar
I've actually saw a video how to do that. Thanks. Is it necessary to take the main caps though?
Old Nov 20, 2014 | 12:40 PM
laurentj23's Avatar
Where do you get the tools from. The jaw puller is from advanced and the bolts puller is from autozone. I just used the bolts that were supplied by the kit. But it's out now. But I'll keep it in mind . I'm sure I have to remove the pulley in the future.
Thanks guys!
Old Nov 20, 2014 | 01:13 PM
JRENIGAR's Avatar
No, main caps stay torqued down or the reading would be wrong.
