Can I port my tb?
Old May 26, 2004 | 07:06 PM
TexMax's Avatar
Default Can I port my tb?
Does anyone know if it is possible to port your throttle body yourself? If so, is there a write up on it anywhere? How much hp is it worth?
Old May 26, 2004 | 07:35 PM
felton316's Avatar
Yes, its possible to port one's own throttle body. I did mine myself.
Old May 26, 2004 | 08:26 PM
jimmyblue's Avatar
Moderator
I did, there are, dunno.
Think ls1howto.com had a writeup and if you searched
right here for "home port TB" you would probably turn
up plenty. Maybe even dyno before / after info.
Old May 26, 2004 | 10:33 PM
TexMax's Avatar
Does anyone know where I could find a writeup on how to port a tb? Thanks!
Old May 27, 2004 | 03:20 AM
Judd's Avatar
Here is a few pics and a short overveiw of mine-
http://www.cardomain.com/memberpage/296918/6
Old May 27, 2004 | 06:55 AM
apexman's Avatar
www.installuniversity.com has a how to.
Old Oct 18, 2004 | 12:58 PM
black_knight's Avatar
Originally Posted by apexman
Actually, no they do not. They have how to remove and install a throttle body. They don't have anything about how to port one.
Does anyone have a document or how-to on home porting a throttle body?
Old Oct 18, 2004 | 02:07 PM
Matt D's Avatar
Retired Street Racer
look in gmhightech performance magazine a few months back
Old Oct 18, 2004 | 02:12 PM
cyphur's Avatar
hmm, i've ported a few. i'm gettin into porting them, as a local thing for now(not trying to become the next janzter, so don't take it there please, and no this isn't an advertisement). here's a link that might help you out. http://www.ls1camaro.net/sections.ph...ticle&artid=16 pm if you'd like to talk about it more.
Old Oct 18, 2004 | 09:45 PM
2000WS6Vert's Avatar
I just did mine tonight. It wasn't that bad. A dremel tool with the coarse sanding wheel(get at least a dozen) and away you go! I also trimed the bar in half and cut the screws on the backside. I'm not sure how much of a difference it will make, but every little bit helps.
Old Oct 19, 2004 | 08:20 AM
Ah, thank you gentlemen! That's just what I was looking for!
