accessory spacing.
Old Jan 4, 2015 | 10:42 AM
formula218's Avatar
Default accessory spacing.
i'm putting a 5.3 into a '94 bird. i've got a LS1 water pump, LS1 PS pump, the stock alt. for the motor (LM7) and stock crank pulley. will the LS1 pumps work without spacers? or would it be easier to change the crank pulley?
Old Jan 4, 2015 | 10:55 AM
garys 68's Avatar
What alt/PS pump bracket do you have?
Old Jan 4, 2015 | 02:12 PM
formula218's Avatar
LS1 f-body
Old Jan 4, 2015 | 02:27 PM
formula218's Avatar
would swapping to a LS2 crank pulley fix my problem.
Old Jan 4, 2015 | 03:15 PM
garys 68's Avatar
Run a f body/GTO LS1 crank pulley, accessory bracket, PS pump, etc. An LS2 pully could be from a vette (wont work), or GTO (will work).
What are your plans for AC?
Old Jan 4, 2015 | 07:05 PM
formula218's Avatar
awesome, then the pulley swap it is. a friend has one off his GTO.
don't have AC.
Old Jan 4, 2015 | 07:09 PM
formula218's Avatar
do i need to get a new LS1/LS2 crank pulley bolt? or can i reuse the one on the 5.3 crank?
Old Jan 4, 2015 | 11:13 PM
garys 68's Avatar
That's a single use TTY bolt. Buy a new one, use the old to pull the pulley in place.
Old Jan 5, 2015 | 04:44 AM
formula218's Avatar
will do, thanks for your help!
