Dorman ls6 intake 615-900
I'm thinking I'd be better off finding a used ls6 for around $350. I'd end up spending the same for the dorman and crossover pipe.
I feel my intake will make more power then a ls6..when you see the wedges in the ports and the tb opening you will understand if it made 5hp less on a 550hp motor then a ls6 in stock form then once you clean it up to how it should be you will understand why I say this..I wish I would of measured the max wedge size but it had to be around 1/4 an it sloped from that at the top to nothing which was prob 1.5" total an 2 ports had that twice in them so this makes for a big obstruction not to mention what it caused air to do right before it hit the head ports..
I paid 25$ for the 500 grit and a mix pack of 50 cartridge rolls from harbor freight an had around 4hrs probably porting it and I won't even lie the night I finished it I used a cordless drill to do half the work seeing it was 2am an I didn't want to wake my neighbors up with my compressor constantly going an I wanted to get it done...its really a easy job,don't stay in one spot,take your time and feel the port with your fingers,have a good light source..
Separate question: I need to remove the ridges in the intake runners and widen the throttle body opening when porting the dorman intake, correct? Anything else? I've got a ported Potz Speed TB and Powerbond UD on the way as well. I should see a nice power bump with those.
https://ls1tech.com/forums/generatio...take-pics.html
bottom of the intake is up in these pics an the one i posted before..the double wedge port..ones on the floor facing out and then the other is on roof facing in on the intake runners.
one on the floor that i was almost done blending with..this is the wedge that faces towards the heads
before
