Dorman ls6 intake 615-900
Old Feb 23, 2015 | 02:50 PM
  #81
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'm on the rig for a few days yet. When I get home and have a minute I will.
I've got an Escalade that needs new motor and trans mounts, a seat heater control board fix, oil change, and new brakes.
Yay me
Old Feb 23, 2015 | 04:48 PM
  #82
sawblade99Z's Avatar
I've got a Camaro that needs to be finished and a truck that will do everything but start about ready to set the truck in fire. Anyway, I was under the impression the difference between the ls1 and ls6 intakes was just the actual volume, not the TB opening. And I thought they were like 75 mm. Maybe 76? Idk.
Old Feb 24, 2015 | 11:10 AM
  #83
gagliano7's Avatar
If anyone cares Rockauto has it for $309
Old Feb 24, 2015 | 05:32 PM
  #84
slogo's Avatar
Only place i could get 76mm was at the very edge of the opening, down
the throat it was hard to find 76mm
Attached Thumbnails Dorman ls6 intake 615-900-dscn0554.jpg   Dorman ls6 intake 615-900-dscn0551.jpg   Dorman ls6 intake 615-900-dscn0558.jpg
Old Feb 24, 2015 | 05:58 PM
  #85
slogo's Avatar
Sorry, I am not a photographer. these pictures show how much you would
have to bore to get 78mm, looks like you might could get 79mm if you did all
the work op did. And Im sure all of the intakes are a little different.
And this is a true ls6 manifold.
Attached Thumbnails Dorman ls6 intake 615-900-img_0731.jpg   Dorman ls6 intake 615-900-img_0732.jpg   Dorman ls6 intake 615-900-img_0733.jpg
Old Feb 24, 2015 | 07:12 PM
  #86
Thanks for the pics! I'm going to buy some calipers while I'm at the store for the sanding rolls. Anxious to see how it compares to what you posted. Hopefully tomorrow night I'll have measurement pics up.
Old Feb 24, 2015 | 07:14 PM
  #87
Carguy8888's Avatar
What an exciting thread, in for more.
  #88
MMorgan9812's Avatar
Old Feb 25, 2015 | 09:51 AM
  #89
RyanS13's Avatar
ordered through a salvage yard that gets dorman aftermarket parts, it was drop shipped from Dorman to them, return address was a dorman warehouse in TN. came on fedex, i was there for the box opening.
If you order from a place that has stock on hand, i bet it gets double boxed. but they said dorman ships every thing lately in the items box, they get broken head lights all the time and hate the delay it causes.
Originally Posted by sawblade99Z
Will you kindly?
And to everyone else, just curious where you're ordering them from? Mine was packed very well.
Old Feb 26, 2015 | 01:53 PM
  #90
Rhody-Firehawk's Avatar
question from a lurker.
for those how have installed this intake, do the coolant lines fit (looks like they might from the shots I've seen of the bottom) or do they need to be plugged?
Old Feb 26, 2015 | 01:58 PM
  #91
Assuming you still have an ls1 intake currently, you'll have to switch. Ls1 lines run under whereas the ls6 lines go over. Being an ls6 replacement, this intake is notched over the top to fit it. You can buy the crossover line to fit the ls6 and this from one of the vendors on here.
Old Mar 7, 2015 | 04:43 PM
  #92
fsvaasam's Avatar
Any new happy owners with this intake around or someting new information?
Im about to get one and looking for more information. I was wondering too if sawblade99Z have some bigger throttlebody than stock, when it needs to be ported?
Old Mar 7, 2015 | 07:24 PM
  #93
HulkRogan's Avatar
Here's the finished throttle body. Hand sanded. 78mm out front and very similar all the way back. Finest I've used thus far is 400 grit. I still have to get a sheet of 1000 grit to put the finishing touch on it. However, there's about a 100% chance I'll pick it up tomorrow, find something I'm not satisfied with, and then spend a little more time straightening the throat.
whywhathowto.com/how_to_buy_wigs_online.html
http://whywhathowto.com/howtoorderclothesonline.html
whywhathowto.com
www.whywhathowto.com
http://whywhathowto.com/how_to_buy_shoes_online.html
whywhathowto.com
Its a crappy picture, but I measured to show it opened up to 78 mm. Bear in mind that the throat originally had a lip the same thickness as all the others you see there. Ignore the shitty part at the gap on the top right. I was watching Vikings at the same time and lost track of how long I had been in the same spot lol it's ugly and uneven, although the pic makes it look worse than it is. Shouldn't hurt actual performance I wouldn't think.
Comments and suggestions welcome.
Great post, thank you! I am currently trying to find a fix for the same thing...
Old Mar 7, 2015 | 11:35 PM
  #94
I have a stock throttle body at the moment, but I will have a ported stocker to go with this when it gets installed. They are 78 mm so I opened up the inlet to match.
Old Mar 10, 2015 | 10:09 AM
  #95
ToxicWS6's Avatar
i ordered mine from parts geek, it was in the dorman box which was placed in a bigger box with big air bags all around, idk how it broke so easier, i would guess it was broke before shipping
Old Mar 12, 2015 | 08:10 PM
  #96
suicidal racing's Avatar
you should be able to do what people did with the fast intakes and crush the tube down to fit under..their is some how to on this on here
Old May 31, 2015 | 08:18 PM
  #97
RubbercitySS's Avatar
Has anyone installed this intake yet?
Old Jun 1, 2015 | 02:11 PM
  #98
an-i-no's Avatar
Here is mine, with the letters shaved and (poorly) painted.
Ignore the janky coolant crossover hose lol
Old Jun 6, 2015 | 06:39 PM
  #99
DietCoke's Avatar
I ordered one of these today for my exocet motor. cheaper then an ls6, new, and easily ported. cant beat it, really.
Old Jun 10, 2015 | 08:59 PM
  #100
Stuffs's Avatar
updates?
