What MAF with a Fast intake?
Old Feb 16, 2015 | 12:17 AM
SSmokin99's Avatar
Default What MAF with a Fast intake?
What is everyone here using?
Old Feb 16, 2015 | 01:02 AM
Robert Cantu's Avatar
I'm using a 04 Zo6 maf on my ported 90.
Old Feb 16, 2015 | 07:13 AM
HCI2000SS's Avatar
I'm using a stock MAF with my ported 90
Old Feb 16, 2015 | 07:34 AM
redbird555's Avatar
I use a z06/truck maf. They actually measure around 90mm on the id. You could go witha 100mm maf but they are a pain to tune at low speed. FWIW when I tuned my car I had 99-101 kpa all the way 6800 rpm indicating there was no vacuum restriction with the truck maf.
HCI I would ditch the stock maf, its really small. You can pick one up for 40 bucks and just make an adapter harness or buy one you'll be in it for like 75 bucks with the harness and couplers. They're real easy to tune as well
Old Feb 16, 2015 | 08:03 AM
HCI2000SS's Avatar
Your post just made me realize i wasn't even thinking straight when I made that post...no morning coffee yet lol. I forgot I changed it to a LS2 MAF when I switched motors.
Old Feb 16, 2015 | 08:34 AM
roninsonic's Avatar
tsp 100mm housing with five-wire card sensor.
WAS using an slp 85mm.
Old Feb 16, 2015 | 11:56 AM
1 Slow WS6's Avatar
I had an 85 mm on mine with a fast 102. With it on the car and off (tuned in SD) car made the same power.
Old Feb 17, 2015 | 06:39 AM
poltergeist 02's Avatar
I would go with a GM 85mm MAF or have it tuned in SD. Don't bother with the 100mm MAF's.
Old Feb 17, 2015 | 11:01 AM
VandykeT/A's Avatar
I actually made a 100mm maf with a spectre housing fairly cheap but I would personally speed density tune it just make sure your tuner is willing to put the time in on it.
Old Feb 17, 2015 | 02:44 PM
ULTIMATEORANGESS's Avatar
i have SLPs also.
