Dorman ls2 intake?
Old Mar 30, 2018 | 02:45 PM
  #401
Raygunz's Avatar
Default MAP sensor and barb fitting
Old Mar 30, 2018 | 02:54 PM
  #402
omc8's Avatar
Originally Posted by Raygunz
I see we have done some porting to that DLS2 , looks good . So no other mods just intake and 92 mm tb since your last dyno ?
Old Mar 30, 2018 | 07:49 PM
  #403
Raygunz's Avatar
No other mods. So hopefully this dyno will give us a pretty good idea of how much a ported Dorman LS2 actually helps hp when coming from an LS1. The only upgrade is the port and internal post removal. Also the 92 mm throttle body of course.
Old Mar 30, 2018 | 08:37 PM
  #404
Raygunz's Avatar
I also plugged the holes where the posts were with a small bolt and a nut that looked like a rivet. Put a little thread locker on it and some RTV adhesive gasket maker.
Old Mar 31, 2018 | 09:45 AM
  #405
omc8's Avatar
Good this should make for a good comparison. I'm interested to see how well that G plus 92mm tb is going to work for you too. What size maf are you going, Id go to 85 if you re not there yet.
Old Mar 31, 2018 | 10:34 AM
  #406
big hammer's Avatar
85mm truck maf is a must and cheap. You’ll be amazed how much larger internally it actually is compared to an ls1 maf
Old Apr 1, 2018 | 08:56 PM
  #407
Raygunz's Avatar
Finished up the LS2 Dorman intake today. I also installed an oil catch can and some stainless steel braded steam lines. I used the cheap hose the catch can came with for now but will be puttig in some braded ss hoses just to look a little nicer. The install is not difficult just very tedious because everything is so hard to get to and of course the catch can and steam port hoses just added a little more time to the project. Will schedule a tune on a dyno this week to see just how well the HP gain is.
Old Apr 2, 2018 | 09:23 AM
  #408
omc8's Avatar
Looking good how is that throttle body working , do you see any problem with it ? Are you having the car tuned at the Dyno shop ?
Old Apr 2, 2018 | 09:43 AM
  #409
Raygunz's Avatar
I took car for a drive and seems to be running ok. Sounds louder and almost sounds like its cammed. It was already pretty loud with the Speed Engineering headers and true dual exhaust. I didn't get on it hard, waiting till after I take it to shop for tune on a dyno. Taking it to Performance Unlimited here in Corpus Christi, Tx. They tuned it last time when I put the headers and true duals. I believe I hit 342 hp. I will pull up the old graph toake sure.
Old Apr 2, 2018 | 09:52 AM
  #410
Raygunz's Avatar
I had to grind a little on the water pump and under the throttle body. Other than that I just put a little blue thread locker on the blade screws and the bolt on side shaft where cable mounts. I had to grind a little on the opening for the IAC sensor. Other than that just mounted them and adjusted the blade adjustment screw for idle a little bit. Seems to be running ok. Will see what shop tells me when they hook it to computer. I bought the throttle body on Ebay for about $75, looks almost Identical to a WAR throtle body. I could be wrong because I don't have one to compare it to personally.
Old Apr 2, 2018 | 10:19 AM
  #411
Raygunz's Avatar
I tried to use the EGR plug from my ls1 but it leaked even with a bigger O ring.
Old Apr 3, 2018 | 01:01 AM
  #412
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Our billet egr plug is the only one that works as far as i know. Quite a few have been tried.
Old Apr 3, 2018 | 09:50 AM
  #413
Formula81's Avatar
So as far as fuel rails go, I know it's been said that the factory ls1 and ls6 fuel rails work, but I'm putting this intake on a 5.3 swap and was wondering if aftermarket jegs or summit ls1/ls6 fuel rails will work or the ones the WS6 store sells and will the brackets work?
Old Apr 3, 2018 | 06:20 PM
  #414
omc8's Avatar
Thanks for adding the tb info . So you verify that you have full blade opening at wot.How does gas pedal feel , is the cam spring stiffness smiliar to stock . How did you elarge the iac opening ?
Old Apr 3, 2018 | 06:33 PM
  #415
And ls1 style rail will work. Holley sniper etc.
Old Apr 3, 2018 | 09:22 PM
  #416
Formula81's Avatar
Alright, thanks
Old Apr 3, 2018 | 10:16 PM
  #417
Raygunz's Avatar
Car is running and idling good but I don't think its reading WOT. I been driving my truck mostly until I get tune. I did realize that it used to shift hard and now is shifting way too smooth, not as agressive as it used too. On the highway if i punch it it does not down shift and pick up like it used too. I reset the IAC and TPC sensor today but didn't get to drive it. Hopefully that fixed it if not the tuner can fix it. As for making the IAC fit I just grinded the whole inner edge at an angle with my drill and a bit to allow it to fit. It went in and still sealed with the O ring it had.
Old Apr 5, 2018 | 08:23 PM
  #418
Raygunz's Avatar
Ok so I did have to adjust the tps to get it at .5 and at WOT it is reading just under 4.4. Going to have to grind bump stop just a bit to get it to read 4.6 to 4.7. As far as the throttle stiffness, it is a little stiffer but not much and not enough to for me to want to mess with the springs or coils on the side of theottle body. I think after some normal use they should get a little worn in on their own. It looks like I will be taking it in for a tune and dyno on Tuesday. Will let yall know what I gained. After this I think Im saving up for heads and cam. Not really trying to make it a beast because even though I have an Avalanche I drive my TA 80% of the time.
Old Apr 6, 2018 | 09:49 AM
  #419
omc8's Avatar
Thanks for the details of this review keep us posted on progress of the tweaks you continue to make. My guess is that you will make 15 hp gain , hope you see more .Are still running stock injectors, maf and lid ?
Old Apr 6, 2018 | 01:31 PM
  #420
Raygunz's Avatar
Yes, still running stock injectors and MAF but have a high flow lid. MAF is descreened and ported a little.
