Dorman ls2 intake?
Old Dec 20, 2017 | 02:30 PM
  #381
Kfxguy's Avatar
Originally Posted by G Atsma
Not sure he's siding either way. He just put the tests up here for all to see, and someone is having a hard time buying the results.
This is exactly right.
I just posted it because someone sent it to me. If the guy is lying, then he has to live with that I guess. Although like I said, I don’t know why he would be lying but ok. And I still feel like I made a good purchase for the price. It could be the placebo effect, but it’s odd that my fuel trims were within 2% of Zero correction before the intake and then ended up being around 10% correction. But yea I can’t prove anything otherwise because I didn’t dyno the car. I feel good about my choice tho. Eventually I’ll get a lsxr but right now I don’t have the funds. I may even go with a sheet metal intake. Who knows.
Old Dec 20, 2017 | 02:32 PM
  #382
Kfxguy's Avatar
Originally Posted by Joe69z28
Well I thought this Richard H. was a credible legit guy . But you can throw that out the window. This test is bogus to suggest that any dorman intake let alone out of the box .Can hang with the TBSS across the board and under the curve is ludicrous . Don't believe it . What's this guy going to do next , a factory stock cylinder head test and tell us that 862 heads make more power than 243s will .
Just wondering. What’s your reason for posting this? Did you Dyno both intakes and come up with a different outcome? If so, can you post the Dyno videos or Dyno sheets?
Old Dec 20, 2017 | 02:57 PM
  #383
tech@WS6store's Avatar
LS1Tech Premium Sponsor
He means he also did a dyno showing 706 heads made more than 243/241/317 heads on a 5.3l with a cam. Its another dyno he did. And doing so hurt alot of feelings but didnt tell a true story really. As well as posting up some flow results of the heads showing the 706 trumping quite a few even with the smaller intake valve. That and a few other tests have made quite a few people question behind the scenes action. It is debatable to say th least.
Old Dec 20, 2017 | 03:56 PM
  #384
wannafbody's Avatar
On a small bore 5.3, the larger valves are probably shrouded. You'd think the larger volume of the 243 would suck more air in though. Still 2 hp difference between stock heads isn't enough to get worked up over. Do the same test on a 6.0 and I think the 243 head would win by at least 2 hp.
Old Dec 20, 2017 | 04:15 PM
  #385
With the 6.0s bringing a premium a week before Race Wars, everyone does 4.8s and 5.3s especially thanks to viral turbo videos and the "they are so cheap ill blow it up and buy another one" mentality.
If you look at the flow sheets they did, youll definitely scratch your head though.
Trust me, no one would love this comparo more than us, but i dont think it will be such a good performer out of the box that this test showed...BUT that also depends on the revision.
I am fully confident in the DLST manifold though.
Old Dec 20, 2017 | 08:44 PM
  #386
big hammer's Avatar
I’d imagine the dorman would be adequate on a Cam only ls1
Old Dec 20, 2017 | 08:56 PM
  #387
Kfxguy's Avatar
I think it would be adequate for heads and cam car too. I’ll find out, putting heads on this weekend
Old Dec 20, 2017 | 09:17 PM
  #388
JoeNova's Avatar
Restricted User
Anyone go ahead and buy one and want to loan it for a Gen 3 truck vs Dorman LS2 engine dyno test on a LOT of boost?
Old Dec 20, 2017 | 10:17 PM
  #389
dreadpirateroberts's Avatar
I think it's time for some more comparison testing.
Old Dec 20, 2017 | 10:33 PM
  #390
Agreed!
Old Dec 21, 2017 | 02:12 PM
  #391
DangerNoodle's Avatar
Long time lurker.
I have a TBSS intake installed on my GTO. (Full write up is on LS1GTO).
If you want a true comparison, someone send me a dorman LS2 intake and $200 for a retune at Complete Street Performance and I'll get it done.
Old Mar 14, 2018 | 10:46 AM
  #392
357i's Avatar
Did anyone every run this on a boosted setup or pressure test it?
Old Mar 14, 2018 | 09:01 PM
  #393
DietCoke's Avatar
They will come apart under boost. The sonic welds are not very strong. N/A only.
Old Mar 23, 2018 | 12:44 AM
  #394
FUroundeye's Avatar
Where did you see this?
Old Mar 23, 2018 | 01:13 AM
  #395
big hammer's Avatar
Either him or a buddy did it
Old Mar 23, 2018 | 03:33 AM
  #396
DietCoke's Avatar
Just tellin it how it is.
Old Mar 24, 2018 | 12:53 AM
  #397
Formula81's Avatar
How much boost were you running
Old Mar 30, 2018 | 06:37 AM
  #398
Raygunz's Avatar
Been sitting on my Dorman LS2 for about 3 months now. Have a 1999 TA with LS1 intake. Will be installing the LS2 Dorman intake this weekend. Should have a dyno test by next week. Pulled 342hp on dyno with Speed Engineering true duels and headers, also had a ported throttle body and a tune. Hopefully this intake will get me between 360 to 370 hp. It is also an A4.
Old Mar 30, 2018 | 08:56 AM
  #399
Sube's Avatar
I'll be interested in your results, I've been sitting on a Dorman LS2 for a while too.
Old Mar 30, 2018 | 02:39 PM
  #400
Raygunz's Avatar
Default Intake almost ready.
