How to do your own EGR provision on a LS6 manifold?
Originally Posted by DMNSPD
I like that MUCH better than the SLP setup. I think i'll spend the extra money and get the LPE peice since it looks much cleaner. Thanks for the pics!
Glad I could help, I think you'll like it alot it will look completely stock.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Originally Posted by silverbullet00
I would say just delete it it's much easier that way IMO I took mine off, and it was easy. The only hard part was removing the pump from the bottom side of the car on the drivers side, under the fuse box and headlight. If you have to have the egr provison I would buy the slp so you don't have to worry about vacum leaks and the compression fitting not sealing up once you cut out the area.
well were thinking insted of modding an LS6 to exept EGR we will just remove the EGR system, delete it with tuning....then at smog time when we change my tune we will turn EGR back on, slap it back on and just stick the tube right where it goes!
youll never know there isnt a hole in the manafold!
what do you think?
what do you think?
I'll sell you mine ...
It's a CNCed piece of plastic and a tube of sealant.
