How to do your own EGR provision on a LS6 manifold?
Old 05-31-2004, 03:38 PM
It's not mine! woo hoo!
demonspeed's Avatar
Default How to do your own EGR provision on a LS6 manifold?
I'm going to pick up a LS6 manifold for $350 with coolant plugs and such. What all do I need to do my own egr provision like the SLP intake? I don't feel like spending $465 plus $26 for shipping for theirs since it seems like it's just a brass fitting. So what do I need and how do I do it? Thanks!
Old 05-31-2004, 03:44 PM
silverbullet00's Avatar
Are you needing to keep the egr/air system on the car, or can you remove them?
Old 05-31-2004, 04:32 PM
demonspeed's Avatar
Well, I'm not really sure what I want to do with it actually. We have visual emmissions here, but nothing serious like hooked up to a computer or anything. I kinda wanted to keep it there just in case I got a hard time for not having it. Plus I really don't think i'll lose any power if I leave it there.
On the other hand, what is involved for removing the EGR? What does it look like after you're done?
Old 05-31-2004, 07:11 PM
jrp
SN95 Director
jrp's Avatar
not sure if they still sell it but LPE used to make an EGR provison for the ls6 intake you could add on. it was like 150 bucks.
Old 05-31-2004, 07:35 PM
demonspeed's Avatar
This thing?
I don't really understand what/how that works.
Old 05-31-2004, 07:39 PM
jrp
SN95 Director
jrp's Avatar
Originally Posted by DMNSPD
This thing?
ya thats it. im not sure how it seals but thats what you connect your egr to just like the stock ls1 intake. i'd justs as well buy an slp ls6 intake or the holley/weiland before i bought that egr provision add on. or justs !egr
Old 05-31-2004, 07:51 PM
demonspeed's Avatar
Haha, I just can't picture how that thing sits on the intake!
I'll probably just go with the SLP since I don't have much of an option.
Old 05-31-2004, 07:57 PM
jrp
SN95 Director
jrp's Avatar
only logical way is to cut the hole out of the intake and then put the egr provision. but that begs my question on how does it seal up.
Old 05-31-2004, 08:05 PM
demonspeed's Avatar
The description says "Includes special adhesive and instructions".... oh well, I'm not going to bother finding out!
Old 05-31-2004, 08:07 PM
M6HuggerSS's Avatar
im getting ready to try the same thing.....not exactly sure how yet but ill let you know when were done... im guessing just fill in area with epoxy then drill hole and thats it!??
Old 05-31-2004, 08:12 PM
TransAm98's Avatar
I would try a hardware store and look for a compression fitting. That all the slp fitting looks like. I going to try that. A piece of plastic for $150 seems crazy.
Old 05-31-2004, 10:07 PM
I would say just delete it it's much easier that way IMO I took mine off, and it was easy. The only hard part was removing the pump from the bottom side of the car on the drivers side, under the fuse box and headlight. If you have to have the egr provison I would buy the slp so you don't have to worry about vacum leaks and the compression fitting not sealing up once you cut out the area.
Old 06-01-2004, 03:33 AM
smokin' joe 00 ss's Avatar
The LPE works great I put it on my old LS6 intake, you just set it in the cavity for the egr on the intake and use a hole saw to cut the hole then I took it out and cleaned up the cut edges and used the silicon on the bottom of the adapter and set it back in and it looks completly stock just like the LS1 intake.
Old 06-01-2004, 03:52 AM
DaddySS's Avatar
This thing?
I installed it on mine and it works great. You set the block in place, mark the hole, remove the bolck, cut out the hole then the block goes in with sealer. Takes about 45 minutes to get it all done, seals up realy well, and your EGR plumbing slides in just like stock
Old 06-01-2004, 06:50 PM
demonspeed's Avatar
So you'd say that sealant is strong enough to not rip out?
Old 06-01-2004, 07:32 PM
DaddySS's Avatar
The block is a tight fit - without the sealant it would probably hold, with the sealant it's not going anywhere.
Old 06-01-2004, 07:48 PM
Ferocity02's Avatar
I think that thing would be cake to install. All you need is a dremel tool to do it. Use some epoxy to glue it in and them maybe some RTV to make sure it's sealed.
Old 06-01-2004, 10:20 PM
demonspeed's Avatar
You guys wouldn't have any pictures of this peice installed would you?
Old 06-02-2004, 03:32 AM
Theres a pic in this old post. https://ls1tech.com/forums/showthread.php?t=140014
Old 06-02-2004, 07:01 AM
demonspeed's Avatar
Originally Posted by smokin' joe 00 ss
I like that MUCH better than the SLP setup. I think i'll spend the extra money and get the LPE peice since it looks much cleaner. Thanks for the pics!
