Bellow for fast 92/NO MAF/FTP 98mm lid
Old Apr 12, 2015 | 12:32 PM
blk00ss's Avatar
Default Bellow for fast 92/NO MAF/FTP 98mm lid
Just like the title says. Running a FAST 92/92 with a speed density tune and a FTP 98mm lid. Measured with calipers my TB and lid are both almost exactly 4.080" in OD. Also from the back of the neck of the TB to the farthest point on the lid and on the bottom, which is the farthest stretch of real estate, it's a tick over 6".
So do I need a bellow which is 6" with a 4.1" ID or a 4" ID? Also just a straigh piece that's 6" long or one with a bend in it?
Old Apr 12, 2015 | 12:35 PM
Firebirdmuscle's Avatar
The 4"x6" straight coupler should do the trick. That's what I'm running on my 104 lid to 92mm tb.
Old Apr 12, 2015 | 12:46 PM
blk00ss's Avatar
Got a pic of it? It doesn't kink it too bad?
This one here?
http://www.intakehoses.com/mm5/merch...ode=C40B-400X6
Old Apr 12, 2015 | 01:28 PM
01ssreda4's Avatar
I used my old SLP bellow and very slightly modified piece of 4 inch exhaust pipe.
Old Apr 13, 2015 | 10:02 AM
Rise of the Phoenix's Avatar
Here you go OP.
https://ls1tech.com/forums/generatio...-needed-2.html
Old Apr 13, 2015 | 10:56 AM
blk00ss's Avatar
Originally Posted by Rise of the Phoenix
Ummm that's about a stock TB to a SLP lid. Lmao
Old Apr 13, 2015 | 11:29 AM
If you did any research jackass you'd know that it works with the FTP 98mm lid and aftermarket TB.
Old Apr 13, 2015 | 03:51 PM
blk00ss's Avatar
Hey ********** no one jerked your chain. I asked a very specific question. I have researched until I'm blue in the face. Most are for stock ****, and or MAF cars.
I was hoping to see some pictures with setups exactly like mine.
Old Apr 13, 2015 | 04:24 PM
newchevyman's Avatar
He gave you a starting point and you were abrasive. What did you expect?
A 4" intake hose that's 6" long will work fine. I've got one for my setup but I'm having a company custom make one to go over my 102 TB. I have the exact intake hose you need. Will sell it to you cheaper than what you can buy it off intake hoses. If you're interested PM me.
Old Apr 13, 2015 | 07:34 PM
Yeah, and the part number I used works just fine with what you have too. The 4" ID will go over the neck of both the lid and TB.
