What will I gain?
No real need to upgrade fuel rails. You went the FAST 92mm route, which allows you to use stock rails. The FAST 102mm requires different rails. If you were to upgrade rails anyway, you should have just gone with a FAST 102mm. I also agree you're going to need injectors after adding heads and cam. I would look for 42/44lb/hr injectors. Ford green tops would be a good choice
