2000 ss throwing belts(time for a katech manual tensioner)?
My car threw the belt yesterday and roped one of the ribs off. I was wondering should I go with a manual tensioner or replace the oem one. I put the car on the the dunno at slow hawk and put down 329hp and 330tq. I did a fast 1/4 mile rip getting on the highway and when I got home the car was making a sound, that sounded like a bad lifter. I popped the hood and I could see the tensioner bouncing from left to right and making the noise. I shut the car down check things out, and turn it back on and the belt feel right off.
About the most fool proof way of fixing this i have found is to make a guard. Get a piece of aluminum, trace a circle on it larger than your pulley by about 1 1/4" - 1 1/2" cut it out and then put you a hole in the center for the bolt. Your guard will probably need a shim behind to keep it off the pulley and you'll need a little longer bolt. It'll be good for 7k+rpm after that.
Moderator
Received 1,838 Likes
After that, I finally went to a stock-type spring loaded tensioner and haven't looked back.
So I put the old belt back on just so I can move the car. I let the car run for a little and it stayed on and man I the tensioner pretty tight. The car only has 47,xxx miles and the belt only had about 2000miles on it. Just thought I would add that
I had the same issue a few years ago. Got this pulley for about $10 and haven't had a problem since.
https://ls1tech.com/forums/generatio...swap-pics.html
I've had a Katech manual tensioner on my 99Z28 for over 12 years and never had any issues with it causing any premature belt wear, or ever throwing a belt again. FYI, with the Katech or any other manual tensioner you need to use a torque wrench to set the correct tension on the belt(25 lb.ft., Katech), and if the belt is new you'll need to re-torque it after a few hundred miles since the new belt will stretch a little bit. Plus, it just looks a lot better than the bulky gm tensioner.
