01 ZO6 LS6 Intake On SS
As far as the mounting of your throttle cable bracket, the Corvette LS6 manifold does not have the 2 little holes drilled and tapped with brass inserts needed to attach your f-body bracket. You can try to drill into the Corvette manifold, but I don't have a clue as to where you would ever find the threaded brass inserts. I really doubt that they are avail. Maybe you could pull them out of your old manifold.
from this post:
https://ls1tech.com/forums/showthrea...orvette+intake
