Is this throwing off my MAF?
Old Jul 19, 2015 | 01:47 PM
LS2FD3S's Avatar
Default Is this throwing off my MAF?
Well my fabricator made my LS2 intake tube wrong. I asked for a 6AN male connection AFTER the MAF ( I'm using a LS3 card style ) for my line to the passenger valve cover and he put it directly across from the MAF! Is this flow large enough to make it run like **** not being downstream of the sensor?
Old Jul 19, 2015 | 01:57 PM
drew408's Avatar
I'd be afraid of covering the maf with oil.
If the system is sealed,shouldn't make a difference.
Old Jul 19, 2015 | 02:10 PM
LS2FD3S's Avatar
Well it's going through a catch can, and that side is the clean side, you think I'd get alot of oil on that line? I was also thinking if that was the case maybe I could weld a small dam on the inside opening up twords the intake
Old Jul 19, 2015 | 02:19 PM
drew408's Avatar
Why even bother running it back to the intake if you have a catch can?
I run mine str8 off the valve covers and to the catch can.
If u say "for vacuum" just run it to the exhaust like header evac's...it'll put suction on the crank case and no chance of oiling the intake.
Old Jul 19, 2015 | 02:35 PM
LS2FD3S's Avatar
Well I mean you have to run the catch can somewhere, I have a dual, one for the valley cover to intake manifold and the fresh air side, valve cover to intake tube. The issue is everything is already built / welding in 6an for the dual can, every connection, so I'm hoping to make it work.
Old Jul 20, 2015 | 06:32 PM
blackonblacksls's Avatar
The mafs seem pretty sensitive.
If you have any drivability issues, that's probably the first thing you should look at..
Old Jul 22, 2015 | 06:45 AM
Old Geezer's Avatar
" Is this flow large enough to make it run like **** not being downstream of the sensor?"
I'd say yes. ANY disruption to the airflow is going to make for funky MAF readings.
A quik test. Watch the MAF flow w/ the line on, plug the hole in the tube, and see what the reading is...
Old Jul 22, 2015 | 09:34 AM
LS2FD3S's Avatar
Yeah I think the best way to do it is just to move it downstream and plumb it into the coupler
Old Jul 22, 2015 | 09:51 PM
joecar's Avatar
+1 that's a good test.
Can you get your fabricator to weld another one in downstream of the MAF...?
