options for radiator 98 camaro
Old Sep 11, 2015 | 02:03 PM
ssam98's Avatar
Default options for radiator 98 camaro
I need to know my best option for a radiator for 98 Camaro ss 600+hp, I was told by some one the be-cool or is there something better at good price?
Old Sep 11, 2015 | 05:30 PM
ULTIMATEORANGESS's Avatar
LT1 radiators are a popular choice.
Old Sep 11, 2015 | 07:08 PM
01ssreda4's Avatar
Ebay has drop in radiators for fbodies for 175 or less. Just search 98 camaro radiator or whatever and a million will pop up.
Old Sep 11, 2015 | 10:12 PM
ssam98's Avatar
I don't want a eBay radiator I have a 650 hp 10 second car I need maybe be-cool,Ron Davis, Afs or something like that.
Old Sep 11, 2015 | 10:16 PM
01ssreda4's Avatar
They are all aluminum and thicker then stock just like BeCool.
Old Sep 11, 2015 | 10:20 PM
ssam98's Avatar
I like good stuff made in the USA, I don't care about the money just want something good not cheap.
Old Sep 11, 2015 | 10:24 PM
01ssreda4's Avatar
Well then call up BeCool and tell them you want a stock fit radiator for your car. Easy as pie.
Old Sep 11, 2015 | 11:14 PM
ssam98's Avatar
thanks
Old Sep 11, 2015 | 11:19 PM
Paul Bell's Avatar
That's MISTER MODERATOR
I think you've answered your own question here.
Old Sep 12, 2015 | 08:00 AM
01ssreda4's Avatar
And to add to this, a 650hp car that runs 10 secs generally doesn't need a massive radiator, especially for "nyc" weather. I realize I don't know you're specific setup, maybe you're just looking to upgrade which is cool, but you didn't state if there was an actual issue with your stock radiator and overheating.
Old Sep 12, 2015 | 11:49 AM
ssam98's Avatar
No just want to up grade but in the summer with a/c on driving in the the city traffic it runs 220,225 degrees I don't like to see those temp.
Old Sep 12, 2015 | 12:10 PM
Paul Bell's Avatar
220,225 degrees?!? And I thought I had an overheating problem!!
Old Sep 12, 2015 | 12:31 PM
01ssreda4's Avatar
Stock fan settings start at 221 or something close. That's not overheating. I do understand the desire to run cooler though in my gut it makes sense. However, there's always a however, my car always, and I mean always runs faster when I hot lap it. Every single time. That may be in part to the transmission heating up more, and the fluid viscosity thinning over previous runs. My suggestion, before spending undo money, change fan settings. I've had a bunch of combos of thermostats and fan settings and a digital temp gauge for as long as I can remember and that is my educated advice. Maybe your settings are already adjusted, well we don't know because you didn't tell us much.
Old Sep 12, 2015 | 07:32 PM
ssam98's Avatar
My tuner adjusted fan to come on at 190, and I have the SLP fan switch, so on hot days with a/c on I turn on the slp fan switch on high.
Old Sep 13, 2015 | 08:34 AM
01ssreda4's Avatar
With a 160 thermostat, and 190ish fan settings like yours, in 90+ degree LA weather with our god awful humidity mine would still run 210 on the hwy (fans disabled at that speed) and 220 in stop and go. I think in that climate that is the norm.
Old Sep 13, 2015 | 11:41 AM
ramairetransam's Avatar
v6 radiator , better than lt1 radiator as you dont have to plug holes . cu1485 , i got mine for 108 shipped from amazon . ITs the same thickness as the lt1 but you have no extra ports to block off.
Old Sep 14, 2015 | 11:28 AM
imma_stocker's Avatar
Which v6 is same as LT1 minus extra ports?
Old Sep 14, 2015 | 11:30 AM
I don't know. Just get a cu1485 if you have a ls1
