Starter or flywheel no start grinding
Make sure you have the right one. Google images or check p/n's.
Check the starter bolts threads to see if they have ripped threads out of the block (it seems they have. This could be your problem. You might need to repair the blocks threads with HeliCoil).
Make sure you have the correct bolts and not some undersized shitty random ones you found in your garage.
Check the engine block - around where your starter bolts to for damage or welds (previous damage).
Screw the bolts back in the block and wiggle the bolts around to see if there's play.
Install the starter, check if it's mounted straight and check for play (try to move the starter left/right - aim for your b/r and b/l wheels)
Check the starter and ring gear gap. There are heaps of posts/threads regarding this (using a pin between the teeth to measure with). Do a quick google search.
I'm pretty sure the flywheel stops in random spots.
