317 heads for boost...Home Porting ?
Old Mar 2, 2016 | 09:21 AM
Spade's Avatar
Default 317 heads for boost...Home Porting ?
Curious on what you guys recommend for just doing a simple home port job? These are going on my boosted 370 build. Figured I have everything apart I could just clean the heads up easy enough. I am also in no real rush. I have done some searching around but figured I would still ask.
Old Mar 2, 2016 | 01:10 PM
Darth_V8r's Avatar
Moderator
I recommend you don't do it. Very few people truly have a knack for it. If you want horse around on a set of junk heads for the experience, that's different. By the time you buy what you need to do a not harmful job, you're halfway to sending them to AI or Livernois for proven results.
Old Mar 2, 2016 | 01:28 PM
Spade's Avatar
Lol, I have thought about that as well.
Old Mar 2, 2016 | 05:03 PM
Darth_V8r's Avatar
Moderator
Let's be honest here - who here has ruined a set of heads on a home port job?
me
Old Mar 2, 2016 | 06:54 PM
jmm98LS1's Avatar
Just turn up the boost instead lol. I made 900rwhp with stock 317s on a 370ci with only 18psi
Old Mar 2, 2016 | 06:59 PM
dckmn52's Avatar
There is power to be had by just cleaning up the rocker stud, and working around the bowl area/against the valve guide. Not extremely time consuming, or difficult to do. Just need a nice aluminum die set and a die grinder.
Old Mar 2, 2016 | 08:51 PM
Spade's Avatar
Haha, true. What rods and pistons where you running? Compression? My goal is a street-able 800ish.
Old Mar 2, 2016 | 08:52 PM
Spade's Avatar
You do that yourself? Does look good. My problem is I have zero experience in that and I have never watched anyone do it. Make it a bit scary to try.
Old Mar 2, 2016 | 10:16 PM
jmm98LS1's Avatar
Cheap Scat I-beams and mahle pistons on a stock crank and main bolts. Compression is 10.3ish.
Old Mar 2, 2016 | 10:19 PM
Spade's Avatar
Did you want your compression that high for street manners? Great numbers for a relatively cheaper build. That's exactly what I am shooting for with my procharger setup.
Old Mar 3, 2016 | 06:11 AM
farmington's Avatar
Looks good? broke through to the water jacket!
Old Mar 3, 2016 | 06:20 AM
jmm98LS1's Avatar
Yep and I run e85 so that helps too.
Old Mar 3, 2016 | 12:04 PM
dckmn52's Avatar
yes that was all me. My machine shop did the valvejob, shaved the valve tips and decked the head .005 when i was done.
lots of youtube how-tos on porting LS heads. It takes a lot of work to **** up a cylinder head completely.
Just need to remember that a little bit goes a long ways, especially on a boosted application.
if youre referring to the hole you see in the runner, that is the rocker boss not the water jacket.
Every CNC LS head on the planet has a hole there, and is normal.
