Which LS spark plug wire set ?
So I'm looking to buy a new set of spark plug wires before I fire this thing. I have the delphi round coil with heat sink and an old set of 7mm truck wires with like 60k on them. I ohm tested three wires and had a total of 80 ohm difference between them.
I made the mistake of looking up wires for the LS motor and you can spend $40-$240 on a set. 7mm-8.5mm
What is everyone using?
I've used stock, Taylor, and MSD (which I am using now). Honestly they all worked fine but I was not ringing out the last one or two hp out of the engines either. Biggest thing, proper length and boot selection so you don't have a wire that develops a break from being improper for the application. On my latest build I am using the MSD wires and pretty happy with them (especially for the price).
