!AIR question.
Old Mar 20, 2016 | 06:06 PM
Jamesyyyy's Avatar
Default !AIR question.
Okay guys started the process of removing the AIR BS, I was just wondering what I should do with the vacuum line that was on top of the "horn looking thing". I have no clue what its called, should I just cap it or?
Jamesyyyy's Avatar
I tried searching on here but most of the threads were too old and pictures wouldn't show.
Old Mar 21, 2016 | 03:48 PM
ggino85's Avatar
Can you snap a picture?
Old Mar 21, 2016 | 04:42 PM
Jamesyyyy's Avatar
Here it is.
Old Mar 21, 2016 | 04:59 PM
ggino85's Avatar
Ok someone else is going to have to jump in here. I have a 98 and I'm positive i don't have that vacuum line. The only thing close to it that i have is the vacuum line on the back of the intake manifold. This appears to be on the driver side and i have nothing over there.
Old Mar 21, 2016 | 05:09 PM
Killer_Z's Avatar
mine had that too. i removed the whole thing. i think thats whats causing my front vents to not blow any air any more.
Old Mar 21, 2016 | 05:36 PM
ggino85's Avatar
If it stopped the vents from operating then its definitely vacuum related and not part of the A.I.R. When you lose vacuum to the hvac controls, the air only blows through the defrost. the A.I.R. system is only to warm up the catalytic converters on startup so that the cats operate efficiently. Cats need to be hot to burn up excess emissions.
Old Mar 22, 2016 | 01:16 PM
Jamesyyyy's Avatar
hmmm wondering if I should just plug it for now.
Old Mar 23, 2016 | 02:29 PM
Killer_Z's Avatar
hmm interesting, cuz that lil acorn thingy was connected to the AIR system as well. and that lil line that is pictured above was left dangling. part of vacuum line i believe. cuz there was 3 hoses connected to it if i recall, 1 for each of the manifolds and 1 leading to the pump. and that lil line was connected on top.
Old Mar 23, 2016 | 03:00 PM
Jamesyyyy's Avatar
I just can't remember what I did with it on my other trans ams. I wanna say I just left it. But I wanna make sure I shouldn't plug it or what.
Old Mar 24, 2016 | 11:08 PM
98redSS's Avatar
Originally Posted by Jamesyyyy
Here it is.
I'm pretty sure the other end of that hose should be connected to the back of your intake manifold. I believe if you remove the other end of that hose, then you can cap the nipple it came off of on the back of the intake. At least that's how I interpreted the other threads on this topic. I'm going to remove the AIR system on mine soon.
Old Mar 25, 2016 | 09:24 AM
'02 WS6's Avatar
That's either the hose to the back of the intake or to the T line at back side of engine bay on driver side, either way, just cap the nipple it was pulled off of and you shouldn't have any problems. Did the exact thing on my Firehawk and intend to do the same on my '98 WS6 pretty soon.
Old Mar 25, 2016 | 02:46 PM
SlasherVRGR's Avatar
I just tore my intake and heads off and there was nothing remotely similar to this other than the HVAC vacuum line on the passenger side. My AIR system was all just large hoses from each manifold joined into one other large hose routed to the AIR pump near the drivers side turn signal. I have a 98 z28
Old Mar 27, 2016 | 07:51 AM
RollinSScamaro's Avatar
I'm pretty sure you need to plug that.. I just did mine not too long ago and I found a real good old thread on it that was laid out real well.. I'll see if I can go take a look and verify if you don't have it figured out yet..
Old Mar 27, 2016 | 09:53 AM
From driver side going to back of the intake.. put some RTV on a screw and blocked it off.. should be the same one in your picture but hard to tell
Old Mar 27, 2016 | 08:21 PM
hokie00 TA's Avatar
The only vacuum line that needs to be attached to anything is the line coming out of the harness on the passenger side take the T fitting form the back of the intake and plug the line coming From the harness directly into the back of the intake and throw the rest of the fittings and lines in the trash.
