Trick Flow coolant crossover
http://m.summitracing.com/parts/tfs-306sb601k
https://ls1tech.com/forums/generatio...l-motor-3.html
Jason.
when time comes.
Heres another thread with a couple more ideas and ways to do this. A couple like of setups like "realcanuk". I think I had about $100 in to mine.
https://ls1tech.com/forums/generatio...ant-tubes.html
The Trick Flow kit will not work with a BBK intake without grinding on the back passenger side corner of the intake. I was trying to reinstall my intake yesterday with the rear steam ports hooked up and the passenger rear one was making the intake sit about a 1/16" off from the bolt holes in the heads lining up. Being that I have been messing with trying to get all four corners hooked again for over a month this was the last straw and I just hooked the front 2 up using the Trick Flow pieces. Being that the install sheet you get from Trick Flow shows a 4 barrel intake, I'm assuming this is what the kit is designed for. Now I am just where I started with the front to port connected and they make connecting the EVAP and PCV hoses much more difficult due to them being much taller than a factory coolant crossover.
