Cherry red headers
Old Apr 20, 2016 | 07:25 PM
SwEeTWs6's Avatar
Default Cherry red headers
Hey guys so I did the cam, valve springs and injectors then had the car tuned.... Decided to do heads with bigger headers along with racetronix in tank pump.... Car runs and drives but the headers get cherry red I know a retune is prob needed just wanted your inputs....
Thanks
Old Apr 21, 2016 | 09:13 AM
SwEeTWs6's Avatar
anyone?
Old Apr 21, 2016 | 09:17 AM
kinglt-1's Avatar
cherry red headers indicate a timing issue. You sure the cam was dot to dot when installed?
Old Apr 21, 2016 | 09:47 AM
blk00ss's Avatar
I had a fast 90 bottom shell crack on me once. It idled around 2500 rpm and had the headers glowing red. So I would say it can also be a lean issue. New heads, and cam will want a good bit more fuel.
Old Apr 21, 2016 | 12:25 PM
kingtal0n's Avatar
Check your timing, check your a/f ratio
At idle, it might be difficult to glow red with simply a lean condition. It usually takes an exhaust restriction, or severely reduced ignition timing, to cause a red condition at idle. Unless the tube is very thin walled (I am more used to turbocharger manifolds which are far thicker).
Biggest dangers are, you could melt/warp the parts of the engine, like the header flange or head. Also if any water splashes up on them while they are that hot they might crack. Did you degree wheel the new cam?
Old Apr 21, 2016 | 02:37 PM
SwEeTWs6's Avatar
When I installed the cam and springs and had the car tuned it was fine and running very well.... After that I decided to buy some 799 heads p&p with 3 angel valve job and the fast92mm with 92mm throttle body..... The idle on initial startup will rev to about 1500rpm and surge until it warms up then its idling at 1200..... If I drive for a bit and press the clutch in idle will jump to 2000 then come back down but does like to hang here and there.... I am 100% sure the cam is dot to dot.... Nope I didn't degree the cam.... I have the catted Y hooked to the headers no exhaust....
Old Apr 21, 2016 | 05:55 PM
SwEeTWs6's Avatar
Tps was 0-0.47 with koeo and 3.18 at wot...... I took screen shots of the data if anyone would care to analyze it I would greatly appreciate it....
Old Apr 21, 2016 | 06:15 PM
blk00ss's Avatar
Sounds like you got a vacuum leak. But it's obviously timing.....
Old Apr 21, 2016 | 06:31 PM
SwEeTWs6's Avatar
fudge now I have to chase yet again lol.... My tuner suggested the small line on the back of the manifold...
Old Apr 21, 2016 | 07:56 PM
blk00ss's Avatar
May be. That's easy to figure out. But I ran mine without that hooked up for a long time. Lmao. It idled fine.
Old Apr 21, 2016 | 09:14 PM
SwEeTWs6's Avatar
Thanks guys ill keep ya posted on what he finds either tomm or next week.....
Old Apr 22, 2016 | 06:57 AM
SlasherVRGR's Avatar
Did you replace the valley cover bolts with the button bolts?
Old Apr 22, 2016 | 05:35 PM
SwEeTWs6's Avatar
I'm also leaning towards the ebay throttle body causing some issues as well
Old Apr 22, 2016 | 05:36 PM
SwEeTWs6's Avatar
yea replaced the bolts to button....
Old Apr 23, 2016 | 08:49 AM
Just making sure the intake didn't get cracked.. You'd be shocked at how many people have cracked them due to not changing the cover bolts.
Old Apr 23, 2016 | 07:05 PM
Darth_V8r's Avatar
Moderator
I had a stock 3.0 v6 do that once due to plugged cats. I suggest checking your cats
Old Apr 23, 2016 | 08:51 PM
SwEeTWs6's Avatar
Thanks guys..... Ordered my NW throttle body = )
Old Apr 23, 2016 | 09:39 PM
kingtal0n's Avatar
If an engine springs a vacuum leak the RPM increases with its magnitude. A large enough vacuum leak to cause a serious lean condition at idle will make the engine "pop, skip and jump"(backfire, miss, sputter) as if it had a radiacal camshaft (almost) and the idle will be higher than it should be, as an obvious indicator. It is very rare to see a glowing exhaust in this condition because the temperature generated by the lean condition is not excessive near idle speeds,, because the quantity of fuel is minimal (there is very little fuel mass to extract energy from near idle speeds)
Old May 11, 2016 | 09:50 AM
SwEeTWs6's Avatar
Thanks for all the help guys.... Car runs awsome now and put down 420rwhp = )
Old May 11, 2016 | 11:49 AM
Chris Paveglio's Avatar
so, what was the issue finally? Just a new tune? Vac leak?
