Driver side head running 45 degrees hotter
Old Jul 25, 2016 | 09:27 PM
Oneshotpaddy's Avatar
Default Driver side head running 45 degrees hotter
Fresh build on my ls1. Driver side head heats up fast and runs 45 degrees hotter than passenger side. I have the air bled out of the system and so on. I'm wondering if the engine guy put one of the head gaskets on wrong. The driver side head will get to 160 and I can see the Thermo open for the by pass and the passenger side temp gauge hasn't moved to 100 yet. It takes awhile for that side to come up but once it comes up to 160 the driver side is up around 200. I'm hoping I don't have to pull the heads on a brand new build maybe I'm missing something. hope someone can steer me in the right direction
Old Jul 25, 2016 | 10:38 PM
Majestic9C1's Avatar
hows the steam port routing??
Old Jul 25, 2016 | 11:01 PM
BlackDuk98's Avatar
What head gaskets are you running? On my oem 6.0/6.2 gaskets, there is a tab that has a space before the "6.0/6.2" logo. Numbers should be to the front of the motor on both pass and driver side. I can take a pic tomorrow if needed.
-Mark jr.
Old Jul 25, 2016 | 11:25 PM
The steam line is tapped into the water pump and I'm not sure how the gaskets were installed. I'm wondering if anyone has encountered this before I pull the heads.
Old Jul 25, 2016 | 11:35 PM
BlackDuk98's Avatar
The numbers should be pointing to the front of the car
You don't have to pull the heads to look at the gasket tab. They hang out of the head
I will take a pic in a few mins, I have a gasket laying around
Old Jul 26, 2016 | 05:25 AM
Mine don't have that tab on them. 😞
Old Jul 26, 2016 | 07:34 AM
98cherrySS's Avatar
Possibly a clogged cat?
Old Jul 26, 2016 | 08:35 AM
No cats.
