LS Swap Starter won't spin
Old Jul 26, 2016 | 07:59 PM
Pootis's Avatar
Default LS Swap Starter won't spin
Weird issue I am having with my LS Swap'd E30. Finally got to the point to try to start it and ran into an issue. The starter will not spin the bendix will initiate into the flywheel but will not spin and then when I let off the key it clicks back. Now I have tested the battery it is good. I tried a new starter still the same thing. I added extra grounds still does the same thing. Last ditch effort I jumped the battery and it still did the same thing. So I wanted to get your opinion of things to try. At this point I think it is one of two things either the starter isn't aligned correctly and needs shims or the bmw ignition is not sending enough amps to the starter. But I was told that LS starters don't typically need shims. I added a video below any insight you have would be appreciated.
Old Jul 26, 2016 | 10:04 PM
S10xGN's Avatar
Have tried turning it over by hand, socket on the balancer bolt?
Old Jul 27, 2016 | 07:16 AM
Pootis's Avatar
Yeah the motor cranks over by hand fine
Old Jul 27, 2016 | 01:29 PM
squarles67's Avatar
This is going to sound like a dumb question but you do have the big wire (min 2 gauge) going direct from the positive battery post to the large terminal on the starter right?
Old Jul 27, 2016 | 01:44 PM
Pootis's Avatar
Not necessarily the battery is in the trunk but I have it hooked up to the designated wire on my standalone wiring harness. should I try to directly hook it up?
Old Jul 27, 2016 | 01:59 PM
squarles67's Avatar
That's why you only get a click. The 12V from the ignition switch goes to the small terminal to engage the solenoid.
The starter motor should have a large gauge wire direct to the large terminal on the starter.
Old Jul 27, 2016 | 02:11 PM
Pootis's Avatar
Do people not normally use the wire that is designated for it on a standalone swap harness?
Old Jul 27, 2016 | 02:17 PM
squarles67's Avatar
Here is a thread that may help https://ls1tech.com/forums/conversio...er-wiring.html
There are two wires required for the starter to function, the one from your harness and the main power cable to the battery.
Old Jul 28, 2016 | 07:11 AM
Pootis's Avatar
Ah I'm an idiot thanks for the help
Old Aug 5, 2016 | 04:22 PM
Pootis's Avatar
Ok got the starter working and the car fires up but won't stay running I have VATS turned off and the fuel pump is on and stays running after cranking it so I'm back lost. I have tried with the maf plugged in and with it not. The tune is for a ls1 map and I am using a truck map could that be the cause?
Here is a video of what it is doing
