4l60e problems
When the Cooler Line blew off the first time, how much fluid did you lose and did you drive it after the lose of fluid ???
The second time the line blew off how much fluid did you lose and did you drive it after the lose of fluid ???
Where I'm going with this is not a good place but.... if you ran the trans low and hot and then put it on a dyno even know nothing happen "on" the Dyno there is a good chance you burnt it up
PS
Whoever told you overfilling a transmission cant hurt something is wrong.
Overfilling an automatic transmission causes the fluid to foam, leading to erratic gear shifting, oil starvation and transmission damage.
It is common to overfill a 4l60e to help prevent the pan from being sucked dry during wot for the 2-3 shift when the 3-4 clutch pack is applied and the 2-4 band is released
