intake bolts
Old Nov 24, 2016 | 08:10 AM
2000BLKBIRD's Avatar
Default intake bolts
Did something real dumb.Took of intake and replaced valley cover gasket,oil pressure sensor and knock sensor.All went good.Put intake back on and thought bolts were torqued to 44 ft lbs and 88 ft lbs.Did not see that it is inch lbs.Did not torque to 44 ft lbs of course but I did tighten them pretty good much more than 7 and 8 ft lbs.Should I just leave alone or loosen and re torque?I'm afraid if I start over I might start stripping bolts.
Old Nov 24, 2016 | 08:34 AM
.boB's Avatar
Start over. It's a plastic intake manifold. Too much torque + vibration will crack it. If it's not cracked already.
Remove all the bolts,, remove the manifold and give it a really good inspection inside and out. Install with new bolts.
Old Nov 24, 2016 | 09:31 AM
Can I use same bolts if they back out ok
Old Nov 24, 2016 | 09:22 PM
.boB's Avatar
Same thing. Careful inspection, make sure they're straight and the threads are in good shape.
Old Nov 24, 2016 | 11:05 PM
truckdoug's Avatar
replace them. they are all sorts of suck to remove without pulling the head if they break below flush
Old Nov 27, 2016 | 06:54 PM
unit's Avatar
Do replace the bolts. They are certainly stretched to the limit and may break if reused. One or two might even break when you remove them. Good luck with it!
Old Nov 27, 2016 | 07:14 PM
I backed them loose and retightened them to correct torque.....I think.
Car seems to run great.Should I just leave it alone for now?I'm afraid
the more I mess with it the greater the chance I might break a bolt or strip the bolt.The only torque wrench I had was in ft lbs so I converted to inch lbs
and I think I got them close.
Old Nov 27, 2016 | 08:48 PM
.boB's Avatar
I think you're skirting with danger. You didn't remove the manifold or bolts for inspection. Any of them could be cracked, and that could cause a failure when you least want one. Murphey's Law and all that.
You also didn't use the correct tool. Your torque wrench probably isn't that accurate at 3.5 ft/lbs. Spend a little money and buy the correct tool. They're really not that expensive.
If you don't have the time or tools to do it right the first time, where will you find them to do it a second time?
Old Nov 27, 2016 | 10:21 PM
unit's Avatar
Might as well leave them alone at this point. If they haven't broken by now, they aren't likely to break at the spec torque. Just be sure to plan on new bolts if you ever have to remove the intake in the future.
