Speed Engineering True Dual Exhaust Kits!!
#403
I put in an extra hanger in front of the axle and measured it. I have a beer can of clearance at minimum. If they bent the pipes in front of the axle a little different they could get another 1/2" to 3/4" clearance.
#406
Moderator
Received 1,838 Likes
Originally Posted by JohnR
So, what is it that is welded?
John
John
#410
I just don't get the ppl "not you big hammer" that are stock ride height and are saying that they don't have clearance or have like 3/4 for clearance being stock ride height.
#414
#415
Just finished installing speed engineering's true dual on my 02 z28 and am very happy with how it turned out. As others have stated the bolts for the clamps are total junk, I wasted my time trying to use them but ended up buying grade 8 hardware to replace. You must take your time - clamp the pipes look at it, loosen pieces and keep tweaking it until you get everything looking good. This took sometime but was well worth it.
#417
Just ordered an SE rear exit, as soon as it gets delivered ill install it and let you guys know how it goes. its going on a twin turbo TA that is lowered on hotchkis springs. Car has a umi torque arm mount that scrapes on basically everything already so im not to worried about it.
#419
Moderator
And no, it wasn't out of boredom. I seen hioSSilver post about it somewhere and decided it looks like a good idea.
