Expected HP question
Old Feb 1, 2017 | 07:52 PM
Cody's Avatar
Default Expected HP question
I'm still relatively new to LS's so I wanted to ask this. I have a 2001 LS1 engine with a gm hot cam, an LS6 intake and the heads are marked 241. What kind of power should I expect to see from this combo? I did not build it it cam this way. The engine has about 10k on it since a rebuild.
Old Feb 1, 2017 | 08:01 PM
Cajun ELESS-ONE's Avatar
my guess if its tuned well for the mods between 340-360 hp.
Old Feb 2, 2017 | 10:26 PM
HeavyMetl's Avatar
At the tire. Easily over 400 crank horsepower.
Old Feb 3, 2017 | 10:18 AM
nine8ss's Avatar
A mild cam with factory manifolds will make 340 if you are lucky.
Old Feb 3, 2017 | 03:44 PM
Cody's Avatar
I appreciate the input guys but there seems to be 2 camps on this. 2 of you say 340 - 360 hp the other states 400 crank. Stock hp is 350 crank hp so I would be loosing hp with a statement of 340. I'm not doubting anyone but I am trying to get a better understanding of how I would loose at least 10 hp with a cam and LS6 intake. Can you guys elaborate for me?
Old Feb 3, 2017 | 04:35 PM
340-360 at the WHEELS. 400 at the crank. Wheels is less due to drivetrain losses.
Old Feb 3, 2017 | 04:46 PM
Cody's Avatar
OK, that makes sense. Thank you.
Old Feb 13, 2017 | 06:06 PM
Docrocket1967's Avatar
You will also see a little better numbers running a 6 speed manual over a automatic with the same setup but tunes do change things as well. A good tune can really help
Old Feb 13, 2017 | 08:33 PM
Cody's Avatar
Thanks
