SLP and ZO6 MAF interchangeable?
Old Feb 18, 2017 | 08:10 AM
matt1289's Avatar
Default SLP and ZO6 MAF interchangeable?
Anyone know if the SLP and ZO6 MAF are interchangeable? Research so far is telling me they are the same thing.
Old Feb 18, 2017 | 12:27 PM
taman86's Avatar
no they are not. the slp is a bolt on upgrade for 98-00 cars and 01-02 cars separately. they are separate because of different intakes, cams, and injectors. in the slp there is a resistor in the actual metering part of the maf that tricks the computer into thinking that 'x' amount of air is still flowing through a stock maf. all that does in-turn is allow more air to enter the engine with the 85mm slp maf without adding more fuel based upon the fuel mapping of the stock ecu, so it then leans out the fuel mixture to allow for a more complete burn because the stock fuel mapping is very rich.
the stock 85mm z06 or truck maf is a 5 wire maf which means that the air temp sensor and maf sensor or together in one housing rather then being separate like the f cars wich are three wire maf's and cannot be run the stock 85mm maf is not a direct bolt on swap and will cause the car to run like crap and the ecu will need to be re-flashed with a tuner in order for it to be ran.
hope this helps. I asked this very question a few years ago.
wannafbody's Avatar
I have the Z06 on my 2000 TA with the extra harness wire and it works fine.
Old Feb 19, 2017 | 01:02 AM
2xLS1's Avatar
Cut out the resistor added to the SLP MAF and they are the same. Easy to do with a small pair of diagonal cutters. Although I believe the Z06 doesn't have a screen. And they are no different than the 85mm MAF used on thousands of trucks.
Old Feb 23, 2017 | 09:02 PM
KonkeyDong's Avatar
So you can run the SLP MAF without a tune? Or is that a bad idea?
Old Feb 23, 2017 | 09:41 PM
wannafbody's Avatar
I've run my Z06 meter for about 13 years without a tune and no issues.
Old Feb 24, 2017 | 04:15 PM
KonkeyDong's Avatar
Whaaattt? lol no way. I was wondering more about the SLP MAF though since it is supposed to mock a stock setup, but runs lean.
Old Mar 1, 2017 | 04:03 PM
jimmyblue's Avatar
Moderator
The SLP MAF is "close" to stock cal. Not going to be
perfect, but then neither is the stock tune at the big
end.
You can make a truck MAF (the SLP donor core) or
a Z06 work with the stock tune by duplicating what
SLP did. I have done so, and in one case substituted
a trim-pot for screwdriver tweakability (but with the
tuning software, this is not useful and without, you'd
want some way of telling mixture).
A 85mm stock MAF on a 75mm-set-up vehicle will give
you fuel system rich codes in short order (tried it).
Old Mar 1, 2017 | 06:36 PM
wannafbody's Avatar
I bought mine from Pace and I think they recalibrated them.
Old Mar 2, 2017 | 04:36 PM
KonkeyDong's Avatar
So I shouldnt have any major issues if I delete my EGR and install the new Lid and SLP MAF without a tune?
Old Mar 2, 2017 | 05:15 PM
taman86's Avatar
if you delete the egr you will need a tuner to go in and delete the code from the pcm so it wont throw a ses light
Old Mar 2, 2017 | 05:18 PM
taman86's Avatar
any links to this? as far as know the only way to use a stock 85mm maf is the slp or granatelli way (i think they are the same). other then that you have to have the pcm retuned to get the maf and fuel mixture tables correct.
Old Mar 2, 2017 | 05:21 PM
KonkeyDong's Avatar
So with the codes deleted, the engine will run normal, but with the codes still showing the engine tries to make up the difference? How bad is it to drive on these bolt on type mods with the SES still on?
My SES light has been on since I bought the car and I just posted the codes in the Tuning Section. Theyre for the "Secondary Air Injection (P0410) and Secondary AIR Inject System Banks 1 & 2 (P1415 & P1416), and Cylinder 5 Misfire/Multiple Misfires (P0305 & E0300)".
Old Mar 2, 2017 | 05:59 PM
taman86's Avatar
that misfire is bad. you should get that checked out pronto. other then that maybe somebody who knows obd2 better then me can chime in. i am not sure if those codes will cause the pcm to stay in open loop or closed loop. of it goes into closed loop then its fine to drive on cause then the pcm is adjusting fueling mixture based upon maf, map, 02, tps, iat, and cooling temp sensors. open loop is just a base value that the pcm runs on and is not best for performance.
Old Mar 2, 2017 | 06:15 PM
KonkeyDong's Avatar
Yeah. Im hoping its a plug or wire. Like I said, the car runs fine. No noticeable misses. I was surprised it even threw that code. These codes are also not live codes. Just codes a guy at Oreillys was able to read off.
Old Mar 2, 2017 | 06:25 PM
taman86's Avatar
just thought i should clarify so that somebody doesnt think that im saying its ok to drive on a misfire. misfires are bad.
Old Mar 2, 2017 | 06:41 PM
KonkeyDong's Avatar
I know a misfire is bad. Im just saying it hasnt caused any noticeable issues. Ive read about misfires and a lot of people are talking about "bucking" and "jerking", none of which happens in my car.
Old Mar 2, 2017 | 08:32 PM
wannafbody's Avatar
This is what I used...
http://paceperformance.com/i-6492465...af-3-wire.html
Old Mar 2, 2017 | 08:54 PM
taman86's Avatar
that is just the adapter harness to run a 85mm maf in a fbody cuz the fbody maf and iat sensor is seperate so its a 3 wire maf. the 85mm maf is a 5 wire since the iat is integrated into the sensor. im pretty sure that adapter isnt a plug and play swap to a 85mm stock maf without any tuning iirc...
Old Mar 2, 2017 | 09:15 PM
KonkeyDong's Avatar
The MAF has the adapter already. Ive just read a lot about the SLP MAF and how its supposed to mock stock tables.
Also read the SLP MAF can be MUCH more difficult to tune.
