suggestions..trueduals not loud enough
You must be half deaf, I had an 18" bullet in my I-pipe - "dynomouth", w/ no cats and stock manifolds. It was unbearable to me.I think I would get 12" bullets before I'd run no mufflers at all if this is a street driven car. Just my $.02 Trending Topics
Maybe try 12" bullets. If that doesn't help, just run straight pipes. Or remove the entire exhaust and just run open headers.
I think that if you have a x-pipe and cam with no muffler it should sound pretty good.
But if you're just running straight pipes with no crossover.. It my just be loud and sound like ***.
Removing the muffs will make it a little louder, but probably not enough to impress you, not to mention you'll probably get arrested. Straight pipes also have a different type of sound that you might not like. I'm with the cam guys. The cam will make you much louder and give you the power to back it up. They only cost around $400, which should be a bargain compared to your duals.
Your exhaust is about as loud as they get. At this point, if you want to be louder, you need a cam or more HP... Unless you have a great sound system and a CD of "Top 10 reving LS1s, reving the night away"
