4150 Throttle body questions
Old Apr 22, 2017 | 08:53 PM
moekluse's Avatar
Default 4150 Throttle body questions
Hi everyone, I have a few questions about this Throttle body that will be used on my new vic jr intake.
1: what is this port for:
2: I just want to double check that these 2 ports beside the IAC sensor were just vaccume ports for Ac, brake booster..etc
and 3: most importantly, this was designed to be used with a 1990 5.0 mustang TPS, but I think the 1995 impala one might work. Any ideas if there are any kits that will allow my ls1 TPS to bolt onto this?
thanks in advance for any help
here's another pic, this thing looks pretty sweet..
Old Apr 22, 2017 | 09:01 PM
KCS's Avatar
KCS
Moderator
Moving to Gen III External Section...
Old Apr 22, 2017 | 09:19 PM
moekluse's Avatar
thankyou
Old Apr 22, 2017 | 10:24 PM
RixTrix's Avatar
I think #1 is for a MAP sensor.
#2 center is for an IAC(4 wire stepper), don't know what the two outer ports are.
Cant help on the TPS.
Old Apr 22, 2017 | 10:55 PM
moekluse's Avatar
I cant believe I completely forgot about the map sensor lol. Thank you! This dosent look like an ls map sensor. Any ideas?
I have the ls1 iac that fits fine, just wondering about tps and map sensor now. Thanks
Old Apr 28, 2017 | 07:29 PM
moekluse's Avatar
No one knows about the tps on this thing? Surely someone has experienced this!
Old Apr 29, 2017 | 09:02 PM
S10xGN's Avatar
Your mount setup looks similar to that on my no-name special. I used a spare TPS (& IAC) from from my '87 GN engine and needed to re-pin the connectors to fit the Holley harness shells...
Old Apr 29, 2017 | 09:12 PM
moekluse's Avatar
does the sensor bolt right up? I can modify the harness easy it's just the physical sensor
Old Apr 30, 2017 | 09:02 PM
S10xGN's Avatar
It does on mine, but there are either stand-offs or spacers that make it stick out about 5/8" so the TPS tang fits the tang on the throttle shaft. Can't remember and didn't feel like disassembling. Easily done with aluminum spacers if need be...
Old May 1, 2017 | 04:25 AM
moekluse's Avatar
awesome, thankyou
