Installing 4" Mufflex Help
Old May 5, 2017 | 10:07 AM
ndevin25's Avatar
Default Installing 4" Mufflex Help
Hello, I recentley bought a 4" Mufflex Spintech system and I am going to install it this weekend. I am also replacing my headers with Dynatech headers to I can use the y-pipe that I got on the buy. I was wondering if anyone could give me tips on how to install this system? Any help is appreciated. I am replacing the 2.5" flowmaster exhaust on the car. Thanks.
Old May 5, 2017 | 12:43 PM
omc8's Avatar
You're going to use the spintech muffler ?
Old May 5, 2017 | 01:24 PM
ndevin25's Avatar
Planned on it for the moment being
Old May 5, 2017 | 01:37 PM
omc8's Avatar
Its heavy and does not flow well . There are better choices out there .
Old May 5, 2017 | 01:51 PM
ndevin25's Avatar
Yeah but I paid $350 for it.
ndevin25's Avatar
I plan on getting a different one in the future
Old May 5, 2017 | 02:04 PM
omc8's Avatar
You have the square spintech offset in /out ? Post up a pic of the muffler you have .
Old May 5, 2017 | 03:47 PM
ndevin25's Avatar
Yeah I think it is
Old May 5, 2017 | 09:29 PM
omc8's Avatar
I would sell what you have , you should be able to get your back out of it. And go with a stainless truck kit , then get a single straight through stainless muffler , exit on the driver side. Here is just one truck kit that can be converted, Im not going suggest a certain brand muffler as there are many.
http://www.ebay.com/itm/Stainless-St...VYLj9p&vxp=mtr
Old May 9, 2017 | 02:37 PM
zachm89's Avatar
Aww hell, give the guy a break. Run the Spintech for a bit and if you don't like it cut it off and get another 4" muffler. I've got a similar kit from Hawks for a single in/out 4" with a turndown tucked up at the bumper instead of tips out the back that's going to go on my car. No need trying to resell a kit thats already made to fit the car to then turn around a buy a kit designed for a truck that will require fab work to fit on an fbody, just my opinion though. I will agree however, the spintech mufflers arent the greatest choice, kinda like a chambered flowcrapper.
Old May 10, 2017 | 10:16 AM
omc8's Avatar
Well to each his own opinion , But I don't like doing the same work twice .If he is going change mufflers why not get it right the first time. The system I recommended is about the same money, but its stainless .
And he can design it where he wants it to exit and if he wants a tip or hidden. We do agree on a couple points the single in/out is better and the Spintech muffler is not the best choice. But if stainless is not important to him and he does not care that it does not flow the best , run with it.
Old Dec 28, 2017 | 09:31 AM
99.9percenter's Avatar
Default What tools does this need
How much work does this need?
Old Dec 28, 2017 | 10:09 AM
BOLO's Avatar
Looking at the pic, the over the axle pipe is already welded to the muffler. Hopefully you're installing this on a lift to gain some clearance going over the rear axle.
Old Dec 28, 2017 | 03:34 PM
Full-Force's Avatar
Originally Posted by 99.9percenter
[/QUOTE]
I build lots of exhaust for these cars and I can tell you that not much of that system could be used. Better off just buying some straight tubing and a bunch of 90*'s and doing it from scratch
Old Jan 1, 2018 | 07:43 PM
omc8's Avatar
[/QUOTE]
You need another 45 and 90 or two 90s will do it too. Depending on how you want to place the muffler , if you want it hidden,
a turn down for a tip.
