Vacuum pump for ls1 fbody anyone?
Old Aug 13, 2017 | 07:03 PM
jhshnh's Avatar
Default Vacuum pump for ls1 fbody anyone?
As I'm wrapping up my bolt ons I'm going to try a vacuum pump. It's not a waste of money for me as I'm building a radical 402 llsr. So why not try a vacuum pump now?
Does anyone one have experience with one?
Has anyone tried the GZ motorsports kit?
Old Aug 13, 2017 | 07:18 PM
SoFla01SSLookinstok's Avatar
I have the GZ sportsman kit. I love it.
Old Aug 13, 2017 | 07:48 PM
jhshnh's Avatar
Pics? Easy to install?
Old Aug 13, 2017 | 08:03 PM
I have a couple pics. I'll find. Yes, fairly easy to install. One thing you find out is that the pump will not fit with the A/C accumulator in the stock position. You have to remove the bracket, from the accumulator, so it can be moved to clear the vacuum pump. It's a pretty tight fit with A/C. Ended up fabbing a bracket for the accumulator to hold it.
If you even have A/C lol.
Old Aug 13, 2017 | 08:13 PM
Old Aug 13, 2017 | 08:14 PM
jhshnh's Avatar
I do but I'm pulling it and going to a manual steering rack and electric water pump. Basically alternator and vacuum pump only.
Old Aug 13, 2017 | 08:16 PM
Nice.
Old Aug 13, 2017 | 08:20 PM
jhshnh's Avatar
Thanks for the pic. Did you ever do a before and after dyno? Did it feel different? I know you've done many things to your car.
Old Aug 13, 2017 | 08:30 PM
No problem. Never did a back to back on the dyno. I could definitely feel a difference. The first things I noticed were the engine actually ran better. Noticing at lower rpms it helped with the little bucking I got. Makes the engine feel a bit smoother. I seriously don't want an engine without crankcase vacuum. Definitely worth it to me.
Old Aug 13, 2017 | 08:34 PM
jhshnh's Avatar
Makes sense to me. I'll dyno mine after I do the conversion but it'll also have just the alternator so it won't show just the vacuum pump.
Old Aug 14, 2017 | 01:57 PM
bbond105's Avatar
How does the vacuum pump hold up in a daily driver?
Old Aug 14, 2017 | 02:40 PM
Well. I'm not daily driving the car anymore. But I use it regularly. Off the top of my head I think the pump has been on for 2 years. Maybe 15k miles. Zero problems. If I start to see a difference in vacuum the pump can make. I'll just send it in for a rebuild. Last I checked $75 for rebuild & test.
Old Aug 14, 2017 | 10:15 PM
rednari2's Avatar
Use the smog pump. Old hot rodder trick :-)
Old Aug 15, 2017 | 05:16 PM
jhshnh's Avatar
Smog pump went in the trash a long time ago.
Old Aug 15, 2017 | 05:31 PM
Mike Morris's Avatar
I seen Rick's set up. Looks nice. I have the GZ kit but need to install it. I have AC and EWP with no tensioner.
Old Aug 15, 2017 | 08:00 PM
jhshnh's Avatar
I think I'm going to go with the GZ kit after hearing all the good things about it.
Old Aug 15, 2017 | 08:06 PM
Thanks Mike. Glad to hear you got a pump. So what are you thinking on mounting it/pulley drive since you don't have the tensioner?
Old Aug 16, 2017 | 06:38 PM
I showed them my set up so they worked with me and sent something that should work with what I have. I have not had time for the car and just had to put a rack in it. I will try install soon. I think they are worth a tenth and MPH on most cars.
Old Aug 16, 2017 | 09:54 PM
Nice. Like to see it once it gets done.
Be cool to meet up again. Pretty sure I'll be going to No Guts No Glory in December.
Old Aug 17, 2017 | 05:43 AM
99 Black Bird T/A's Avatar
Did the vacuum pump have any effect on oil pressure if used with a wet sump oil pan?
