Voltage drop when car is hot.
Did the big 3 upgrade. Ground wire, wire to alternator, wire to fuse box. Very minor change of 0.4 volts higher when car is cold to 0 volt difference when car is hot.
Local Midas shop said "Well it hasn't left you stranded..." In other words they couldn't figure it out.
What am I missing?
BTW, 2001 Trans Am.
You will want to check voltage at the battery to verify voltage readings, secondary readings from the cigarette lighter or interior sources may not show actual voltage
When hot take the car to an auto parts store and have the alternator tested with the car running to verify that the regulator reacts to the test to minimum specs.
Car starts up like a champ and seems unaffected by the stereo when I turn it on (aftermarket 2000 watt system installed 6 months after I started having problems)
Today voltage is consistently 0.3 volts higher when hot and the lowest it went was 13.1 volts for a few seconds.
On start-up it was at 14.1 volts.
Average voltage was 13.4 volts.
I feel it should still be higher.
My voltage readings at the dash can show almost half a volt lower than a direct reading at the battery.
I can't blame you,it's annoying to read 12.7 on my radar detector, but I'll pop the hood and test voltage at the battery and find 13.2
So did an experiment. When the voltage was showing 12.7 volts I turned on the stereo and cranked it. It showed 13.3 volts.
I think Chrysler Kid is right. Voltage is shown at alternator output. Voltage at battery during this time was always in the mid 13s.
The best voltage to charge a battery (12 automotive) is 13.4-13.6 Volts.
Years AGO the Voltage Regulator was a mechanical divice with NO "smarts"
TODAY, many inputs control the Alt Voltage Output such as timers, current sense, and temperatures.
The Gauge Reads are often inaccurate, with some in "bits" CAN-2.0B.
I would find ERROR when your charging system did NOT operate as stated.
Lance
On my radar detector it would plop down to 11.8 volts when I roll up my slow windows lol. Hard to say if the body control module is just getting worn, or if these cars have always been like this
Voltage readings at the battery are the best way to find true alt strength
So you're right. Something is worn out or messed up that it's giving us wrong readings inside the car.
