Ls1 vs ls2 difference?
Old Sep 14, 2017 | 06:16 PM
jp98's Avatar
Default Ls1 vs ls2 difference?
Can you tell the difference between an ls1 and a ls2 by looking at them?
the engine is in the car, seller says it is a 408ci now, but the first time we talked he said it was a 383ci.
Old Sep 14, 2017 | 08:08 PM
Not very easily, especially if they are not original. IF it IS original, the LS2 would have drive by wire throttle body, as opposed to one with a pull cable, as LS1's are.
The LS1 is Gen III, where the LS2 is Gen IV. What kind of car is it in?
Old Sep 15, 2017 | 05:38 PM
01ssreda4's Avatar
ls2 is 4 bolt TB stock, but its not hard to swap stuff around.
Old Sep 15, 2017 | 05:51 PM
00pooterSS's Avatar
I'd be really concerned it could be neither if he can't keep up with what he says.
Links below should tell you everything.
-Knock sensors on LS1 in valley cover. On LS2 on side of engine
-Cam sensor on LS1 at rear top of engine behind intake on LS2 in timing cover
-LS2 stamped 6.0 on block
-I think but not sure, I believe the LS2 valley cover has a tube exiting the front like the LS6. I could be wrong, really old braincells being tapped into there.
https://ls1tech.com/forums/generatio...n-ls1-ls2.html
https://www.corvetteforum.com/forums...ac-arrest.html
Old Sep 15, 2017 | 09:54 PM
jp98's Avatar
It is in a 2003 Z06, I should be able to check the cam sensor location.
thanks
Old Sep 16, 2017 | 09:27 AM
Tuskyz28's Avatar
The LS2 should have 243 head casting and 6.0 stamped on the block.
Old Sep 17, 2017 | 12:20 PM
2ToeRacing's Avatar
I wouldn't buy from anyone that didn't know what was in their car. You said he keeps changing his mind. Unless its a ripping deal regardless what motor is in it. Run farest run!!
Old Sep 17, 2017 | 03:04 PM
^^^^^^This!^^^^^^
