Help me plan my Top End Package
You can make good power on a budget but lately its either stock parts or blow the budget up builds. There can be a happy medium, but normally people pull the trigger and order parts then ask questions about them afterward.
Tsp has some very good aftermarket castings that have been updated vs how they used to be in an affordable range. TFS is still the gold standard imo. Not long ago their 220 as casts blew up over tech and the ls scene. They had their internet heyday so to speak but are still very solid performers on a budget with room to grow. Now DART has a few more options but arent proven yet also. Will be interesting to see what goes on with them.
Idk about long deliveries with Mamo. From the time I ordered parts to the time I finished assembly was four weeks.
https://ls1tech.com/forums/generatio...heads-cam.html
500 RWHP is not cheap or easy. If it was, it wouldn't be hand picking CHRS1313 as an example - and his wasn't cheap either
Ported 853 - And it would require serious effort to do worse than these were done.
799's with a valve job, 2.02 intake valve - and on this one discovered the used cam I grabbed was 9 degrees off (advanced). it was torquey as a **** until about 4500 RPM and then fell off fast. It would only take 19 degrees timing.
Then got a cam motion cam and cloyes timing set to replace it - better specs AND not ground wrong (yay) which got me to 370 HP. I still have these heads in my garage BTW. Picked them up used
Then, straight to mamo (cause I realized this incremental build **** was going nowhere fast along with the money I thought I was saving), only change was the heads, fast102 intake, open headers plus 18" extensions, hit 470, and then I just kept trying **** from there.
I literally did not get a single budget part that performed like I thought it would. Add all the fluids and gaskets I went through also to the cost of parts that are now sitting unused in my garage...
Edit - to be fair the cam and Y pipe were killing power the whole time. So it probably would have done better if I'd figured the Y pipe out before I did mamo heads. But it was a budget part too, so lesson still valid.
Well thought out supporting mods are a must, hopefully you got 1 7/8" headers and not 1 3/4". You don't need the most expensive heads to make good numbers.
I know this is a stretch, and a mediocre supercharger kit wouldn't necessarily do this, but i have a serious addiction to modifying to "improve", and after 3 years it becomes what ever i have becomes race car. I wanna do the N/A thing this time, and keep it streetable while make as much power as i can.
MMS 220s are the best Heads for a street/strip especially Auto X
Application (Mast small Bore LS3 for strip/street perhaps).
The MMS 223 Sportsmen can make 460-480 RWHP in a C5
With a 225-229* Intake Duration Cam and paying attention
To details and supporting mods, and will have the best
value/performance, for an Auto X RPM Range ~2500-6000.
I will address tusky's species assertions soon lol.
