Lq4 injector question
I'm putting together an lq4 with a btr stg. 3 truck cam running 799's and long tubes. I have a stock 2001 lq4 intake, rail, and injectors. I've been reading and reading about injectors but seems they all need an adapter or are the wrong height. What would a good plug and play injector be for this set up? Thanks guys
12613411 is the part number. No spacers needed regardless of the old truck intake's fuel rail or the newer truck intake's square fuel rail.
I've used these injectors on both old and new truck intake with no issues.
Wiring connectors are different so that needs to be changed.
The flow rate versus kPa is the giveaway usually as the sticky 36 lb data starts at 39.8 and goes to 43.7.
36 lbers converted to Ve style ecus have flow rate vs kPa starting at 35 and going to 38. Based on 58 psi fuel pressure.
A stock 2011 5.3 tune with those 36 lbers I mentioned has a minimum injector pulse of 0.750 while the 36 lb sticky has a Min Injector Pulse of 1.27 (04 z06 ls6 injectors are 1.26 and people call those 28 lb injectors)
My data for the 36 lbers is derived from spreadsheets based off of reputable tuners such as Marcin Red hard supra as well as Ed Mowton however I understand there is more than one way to skin a cat in terms of what data to use and how it will effect the tuning/tune.
Of course you can tune around different injector data but big weather fluctuations will show the less accurate data in terms of afrs drifting away from their target more often than not. Accurate data will enable the ecu to keep things a bit more steady as the external environment changes.
In my case, I'm SD only now and have had nearly the exact same air fuel ratios at 7 degrees Celsius at full throttle compared to a 23 degree Celsius day (temp I originally tuned at) at full throttle. In the end, if it works it works
Edit: some minor confusion as another spreadsheet gives the following info (1st pic) even though I entered in 37.7 lbs and not 36 lbs. I entered in 37.7 because the resulting 58 psi fuel pressure data shows almost identical data to a stock 2011/2012/2013 5.3 tune (2nd picture)
This has me a bit confused now but based on purely factory tune flow rate values and this spreadsheet, my data is a similar amount lower from the factory values as the 36 lb sticky data is higher from factory values.
Using the sticky 36 lb injector data matches up to the ec tune spreadsheet's 39.87 lb/hr @58 psi value as seen below. So maybe gtp injectors are 39 lbers but it seems like the 12613411 injectors are smaller if you compare factory 2011/12/13 5.3 tunes and the injector data.
Jake fusion, I've looked at many of your posts and they helped me when I was searching so please don't take this the wrong way, it just seems like the sticky data is not quite the final set in stone data for a 36 lb injector at 58 psi.
I wasn't aware that they made a 36 in the later trucks since they were all flex. They had two variants: 42 and 39. Both are 39mm.
I run the L92 Flex 42lbs. The data for them is accurate.
The 39-42 lb part makes a lot more sense as those are on the newer 6.0 truck intakes from the newer years and they are called 12613412 (2013 6.0 Vin G, flex fuel listed on rock auto), just one digit difference. So if Wph351 purchased 1263411, he has to use 4.8/5.3 data from a 2011-2013 tune.
I looked up a stock 2011 gmc sierra HD 6.0 tune and the injector data was almost dead on with the spread sheet in the picture. So at full throttle, zero manifold vacuum (0 kPa in the gray column for ls1 style ecus and at 400 delta Map kPa in the newer ecus) it's supposed to flow 50.4 lbs/hr. Wicked for boost and other big mods!
My confusion earlier was because the spreadsheet data I got based on the factory 2011-13 5.3/4.8 didn't match my current tune for the 36 lb injectors (35 lb in my case). I later remembered that I used the injector flow test ratings for my actual injectors in my tune. It seems like that would be the most accurate way to get data catered to your specific set of 8.
