PCV or catch can advice?
Basically, I have an LS1 with an LS2 intake mani (bought it that way) swapped into a tube frame car. Not sure what I should do with PCV/catch can routing:
If you are to rig up a PCV catch can, you're going to need a can that's sealed (or one of Mighty Mouse's with a VALVED breather that is closed under vacuum).
The line to your valve cover from the top of the throttle body is correct. That is the fresh metered air inlet.
The capped line from the valley cover should go to the top port of a catch can which typically has some sort of mesh or filter to help separate accumulated vapors from the air stream. The outlet of the catch can should go to the capped port on the intake manifold.
The older style PCV valve on the driver side valve cover can either be capped or tee'd into the inlet side of the catch can (top port). Or you could leave the valley cover port capped and run the driver side line to the top of the catch can.
So the way I see it, I need to do one of the following:
- Put a closed catch can on. Input would be the valley cover, output would be the intake mani behind the TB.
- Do #1, but with a PCV valve (pn please?) between the valley cover and the can.
- Run the valley cover into my driver's side catch can.
I'm not sure which way to go, but clearly it being looped is no bueno, correct?
Depending on which of the above routes I take, do I need to do something different with my driver's side catch can?
later year model LS motors do not use a PCV valve. you do not need to use it.
if you have an LS6 valley cover, you should have an air/oil separator in it. you can just use a line from the valley port to the intake manifold and just run it. I am sure there is an LS2 part number for the hose you can use. You don't NEED a catch can.
if you do decide to run a catch can, run one as budracing described. airflow should be from fresh air intake to crankcase to valley cover to catchcan to intake manifold.
#1 is correct.
#2. The output of the valley cover does not require anything more than hose to the can.
#3. You could run the valley cover port to your current can setup, but it would be of no benefit as your draft can seems to be setup properly.
Or should I remove the breather from the catch can and have the driver's valve cover and the valley both go into the catch can, then recirc the "clean" air back into the intake mani behind the TB?
Also, if it helps, my LS1 is from a 2004 GTO, so I believe it has the LS6 valley cover (even though it has the wrong intake mani - from an ls2).
I plan on upgrading my mani to a FAST 90 at some point.
I'm running this inexpensive can: https://www.ebay.com/itm/LS-Catch-Ca...5ZNz2R&vxp=mtr
Easy install, well made, probably won't find a new one cheaper. In the 2nd photo in the ebay listing you can see the filter portion under the removed lid.
https://www.mightymousesolutions.com...en-f-body-mild
You want a can that does NOT:
-have oil build up in the intake
-hurt performance
-have increased pressure that causes seals to blow
-result in smell caused by off gassing into the engine compartment due to use of breather filter
