6.0 Sleeving
On an Aluminum block they can weld the block to add stiffeners and do other modifications that can not be done on cast iron.
I am not sure if they even have a stock replacement sleeve that is thick enough to bore that much and retain it's integrity. But it's not too much more expensive to have some made. Iron takes longer to machine than aluminum too...
Steve at R.E.D. could better answer it for you. He does alot of the aluminum blocks and even developed some of the aftermarket sleeve technology currently used for the LS Engines.
