Dorman Truck Intake info/porting (with pics)
#101
A little progress today between filling holes and porting and porting more oil pumps. Busy week and busy weekend!
Mult pictures so click and scroll
Some reason it has 2 vacuum ports on top, so the extra non fpr one gets shaved and filled. On dbw setups theyll both get shaved and filled.
80mm bbk tb coming in next week to check fitment issues.
#102
Whats the point of the 80mm tb? I measured the TB opening and its 78mm I believe jus the same as the stock TB. The 2mm gained by the TB will just get choked down into the intake opening... unless you open it up but its only a 2mm gain.
What are you filling the holes with?
#103
The holes are being plastic welded by other parts I have cannibalized from other nylon intakes. Cheap, easy, amd effective.
The extra 2mm matters alot in total overall volume. I have seen multiple tests showing gains and had customers ask about them, so why not?
I have contoured the tb opening a bit already so it should not take much more to make it work.
#104
#110
When this isnt the only thing i can focus on, it does get put on the back burner. It will be sent to flow soon along with our ported Dls2. The waiting isnt just because of me but for Wade to get re-settled and get his priorities fixed as well.
#115
would you say this is better in stock form then a stock truck intake? I have 2 5.3s, and i just rebuilt one with H/C/I/E and flat tops... the spare motor came with the dorman intake.. Ill be running a stock cable TB
#116
#118
https://ls1tech.com/forums/generatio...sxrt-more.html
