Which affordable heads?
He and I road raced for a bit and that is what he's looking to do with the car while still being street legal. The seller said its setup currently with a 9.5 cr as he was going to put an sc on it. We'd want to keep it NA and without replacing pistons to bump up cr, what affordable heads on this project to make 525+ crank horsepower and can we mill the heads or use a thinner head gasket to try and get it to over 10 cr.
Looking for suggestions here. Using a 6 speed trans and thinking 3.73 or 3.55 gears.
I'm sure the Vader master has some suggestions?
Our LS2 bore heads start at 65cc and would bump that to 9.77:1 I'd mill them .030 for 60cc (10.4:1) along with .036 piston to head clearance to net 10.46:1. The Fast 102 and a 90mm TB along with a cam in the such as the Summit SUMLSGT108 234/246. I also heavily recommend our steam kit.
Lowest price perf head for a 4.00 bore motor are GMPP CNCed LS3s, not the best but good bang for the buck & GM oem LS3 intakes are pretty cheap also.
Next are prob either of the 2 popular as cast cathedral heads, both have better valve angles than stock heads
http://www.advancedinduction.com/LSX...RGMLS1Head.php
