Fast 90/92 which maf and what size?
Forged ls1, ported 243's, ported fast 90mm/92 nick Williams, speartech standalone harness for gen 3 engines. Couple classified ads right now for 85mm ls6 screenless/screened mafs, truck 90mm maf, 90mm granatelli maf, and stock ls1/ls6 maf. Which would be the best choice and is it as simple as buying the adapter harness to go from a 3 pin to 5 pin for the truck and granatelli maf?
intake will be a 90 degree elbow off the throttle body to a straight pipe (opinion on tube size recommended ?) To a cone style filter.
The efi deal is all new to me so learning all of this stuff from the forum and internet, any info is greatly appreciated
I'm sure you know what they mean. And the most confusing military acronyms are the ones that have multiple meanings. Like IDF.
My speartech harness is for gen3 ls1/6/5.3 etc so it has the 3 pin plug style maf and I would assume it has the iat but the harness is still bring shipped to me do can't verify yet.
I don't have any kind of a tune yet so that will be starting from a clean slate for the tuner, everything I've read speed density is more for boosted cars rather than street daily driven cars and is harder to tune but the guys running can you tell me wether that's true or not ?
My favorite military acronym is probably LPC's... leather personnel carriers.
The difference is SD is based on a theoretical fuel value that uses MAP and rpm, and some other things. Climate and altitude can affect it. Street cars are best off using MAF IMO. I'm sure some die hard SD guys will probably chime in and say it's the best thing ever, but in reality, MAF is just a more effective way to measure air, and not a theoretical table to calculate fuel.
The difference is SD is based on a theoretical fuel value that uses MAP and rpm, and some other things. Climate and altitude can affect it. Street cars are best off using MAF IMO. AGREED I'm sure some die hard SD guys will probably chime in and say it's the best thing ever, YES THEY WILL but in reality, MAF is just a more effective way to measure air, and not a theoretical table to calculate fuel.THATS WHAT IM STICKING WITH
I recommend the 4" 22 deg intake hose part number 22B-400X4
Easy fix for this is to do an open loop (OL) idle using Power Enrichment (PE). PE disables fuel trims, so all that needs to be done is enable it through 1200 or 1600 rpm and set the Equivalence Ratio (EQ) to 1.0 in those rpms. Obviously you'll want to leave PE alone in the higher rpms and shoot for your 12.5 air fuel ratio (AFR) in PE (N/A cars).
Then you have a hybrid tune that uses both SD and MAF.
