Project Car Help
Old Mar 9, 2018 | 10:47 AM
Jamesyyyy's Avatar
Default Project Car Help
Okay guys,I bought a 02 WS6 with a seized motor got it home and as of right now its all apart, and I'm repainting the engine bay, but when I was dropping the motor I noticed the person before me had a T off section from the brake booster vacuum line running all the way to the transmission. The transmission is supposedly a built 4l60E. Only thing I could think of was a manual valve body if that's even possible with this transmission. Do any of you guys know why he could have did that?
Old Mar 9, 2018 | 11:02 AM
ss.slp.ls1's Avatar
Strange, I have no idea. However if that vacuum source is necessary, I would reroute it from somewhere else. I wouldn't want anything T'd off of the brake booster hose that could potentially cause a leak in the future.
Old Mar 9, 2018 | 11:53 AM
Where/how did it attach to the tranny? 4L60E's do not have vacuum modulators.
Old Mar 9, 2018 | 01:06 PM
bbond105's Avatar
I most likely was a manual shift TransGo 4L60E-A shift kit in it that uses a modulator valve.
Old Mar 9, 2018 | 02:10 PM
AnotherWs6's Avatar
Good possibility that's why the previous owner said it was "built". lolz
Old Mar 9, 2018 | 02:58 PM
Jamesyyyy's Avatar
I couldn't believe some of the stuff he had wired up all crazy, and then I saw that. I'm gonna try to attach a picture.
Old Mar 9, 2018 | 03:03 PM
Jamesyyyy's Avatar
Connected here on the tranny
And this was the hose running from the T on the vacuum line to the brake booster
Old Mar 9, 2018 | 04:07 PM
bbond105's Avatar
That would be correct for the TransGo 4L60E-A shift kit.
