Oil Cooler Block-off leaking again
Old May 14, 2018 | 08:14 PM
Monte4ever's Avatar
Default Oil Cooler Block-off leaking again
Hello, I replaced the gasket on my oil cooler block-off with the standard Felpro gasket and it leaked more than the one i took off. Then i bought one of those ICT billet block-offs with the O-ring seal and 1/8 NPT port and it started leaking after a few startups in the garage. If anybody have any experience with this can you please share how you stopped this annoying oil leak. I'm using a F Body oil pan on a iron LQ9.
Old May 14, 2018 | 09:16 PM
I’ve seen these leak, mostly from over tightening the bolts. It warps the block off plate, which is flimsy to start with. Even the aftermarket plates are flimsy, and leak. I have a glass surface plate, that’s flat. I lay a 800 grit sandpaper sheet on it, with cutting fluid on it, and with mounting surface downward, gently move the plate in a figure 8 pattern, for 20 seconds or so. Light pressure. Do not push down hard. New gasket install, and snug the bolts, plus 1/4 turn. Start the engine and watch for leakage. If it still leaks, snug each bolt until leak stops. Done.
Old May 16, 2018 | 06:53 PM
LilJayV10's Avatar
Check to see if both surfaces are flat.
Those bolts only get 89 or 106in/lbs IIRC.
Old May 16, 2018 | 07:02 PM
ss.slp.ls1's Avatar
I would use a generous coating of RTV the next time you put the plate back on.
Old May 16, 2018 | 08:47 PM
LilJayV10's Avatar
Definitely...at least 1/2 the tube.
Old May 17, 2018 | 07:02 AM
RB04Av's Avatar
Make sure the bolt holes aren't stripped. Might have to Heli-Coil them.
Old May 17, 2018 | 03:31 PM
lol!!
Old May 26, 2018 | 10:18 AM
Monte4ever's Avatar
Update:
The oil drip was fixed by trash-canning the ICT blockoff plate for a Earl's Preformance plate. The ICT plate O-ring was actually going across the oil port opening and not sealing.
Old May 26, 2018 | 10:47 AM
Seems like a pattern with ICT stuff. More about looks than correct function.
