2002 ws6 headers
https://m.ebay.com/itm/98-02-CHEVY-CAMARO-Z28-FIREBIRD-TRANS-AM-5-7L-LS1-STAINLESS-STEEL-HEADERS-F/112936151001?hash=item1a4b84e7d9:g:zBEAAOSwSdZWcPi ~
https://m.ebay.com/itm/98-02-CHEVY-C...EAAOSwSdZWcPi~
The highest quality, great fitting, all around great low cost headers I have seen are Speed Engineering. I had a set in my hands this past weekend and after seeing what I saw even if I had the money I wouldn't spend it on higher cost headers. With speed engineering you get more than you pay for. Texas speed has really nice headers as well for low cost, but they are a bit higher than speed engineering, if I remember correctly it's due to a difference in tubing that each of them uses.
Here is headers only at $219
https://www.speed-engineering.com/sh...e-version.html
That's headers only, they have larger primary headers and headers with y pipes etc also
https://www.speed-engineering.com/sh...ion-pipes.html
If you choose to not run cats you can have the rear 02's disabled in the tune
The Kook's headers fit perfect, but they are very expensive. If I could do it over again, I would get the TSP headers and catted-Y pipe. When I needed them, the TSP catted-Y pipe was at least 6-8 weeks out. I couldn't wait that long, so I ended up with Kooks. I have only heard good things about the Speed Engineering headers though.
Some people believe that o2 sensors don't react fast enough in longtubes because of how much further away from the cylinders they are compared to the stock location. I personally have my car tuned open loop speed density all the time and have no issues with it like that. My old daily driver silverado was tuned the same and never had a problem with temp swings from winter to summer. I personally like OLSD right now because its easier to tune and less reliant on sensors for data but I understand the arguments against it.
My car is a dual-cat car from the factory with a SLP LMII catback, would those Speed Engineering headers w/ O2 extensions and Ypipe bolt up to my car without issues?
Im a little rusty with this stuff...as you can see.
I don't know if the headers and Y pipe connect directly to the existing exhaust or if you need to cut the stock pipe or what, contact speed engineering and see. Most people that do headers already have aftermarket exhaust and the Y pipe mates up to that without issue or with a simple cut.
I would upgrade the catback system too, make the most out of installing headers. no point in doing headers and running a cat back that doesn't flow well. Not sure what you have now, but if it isn't that great may want to change that out too.
I think you're mixing up which 02 sensors go where
You put the FRONT 02 sensors into the long tubes to read air/fuel
There are no bungs in the long tubes for rear 02's
If you choose to run catalytic converters the rear 02 sensors would go in behind the cats as they are now, which would be in the Y pipe, not the headers.
There are only 2 bungs in the headers themselves, those are for the two front 02 sensors
They are 8mm x 1.25
I believe the length is 25mm, not 100% positive may be 20mm. Take one out and take it with you for proper lenght
