Help!!! Alternator not charging the battery!!!!
Old Jul 28, 2018 | 06:37 PM
curtisad's Avatar
Default Help!!! Alternator not charging the battery!!!!
I installed a Mechman 250 amp alternator a few weeks ago and I went to the track today to do some bracket racing. Everything was well after my two practice runs, but when I started my car up in the staging lanes I noticed that my gauge was in the red. I ended up winning the race, but I went home after that round in fear of me being left high and dry at the track!
When I got home my battery was reading 11.25 with the car running and 10.75 after I turned off the car. I am thinking that the nut that goes on the back of the alternator, the one that connects to the battery, is loose. At least that is what I am hoping. Does anyone have any alternate theories? The battery should be reading around 14 volts when the car is running and around 12 with the car not running.
Old Jul 28, 2018 | 06:45 PM
Have you checked that nut yet? Wondering why you didn't check it before posting here.....
Old Jul 28, 2018 | 07:48 PM
curtisad's Avatar
that's great advice...no, I haven't checked the nut yet, i'm going to wait till morning when it's not so bloody hot and the engine has cooled down. When I posted this my engine was still hot...
Old Jul 28, 2018 | 08:04 PM
OH OK, gotcha. Yeah, a hot motor DOES slow the investigative process a BIT....
Old Jul 29, 2018 | 06:53 AM
curtisad's Avatar
So, the nut is tight on the alternator. Does anyone have any suggestions?
Old Jul 29, 2018 | 08:24 AM
Majestic9C1's Avatar
bad alternator??.. is the plug plugged in tight?
Old Jul 29, 2018 | 02:40 PM
Old Geezer's Avatar
A volt meter, and a quick test, when the engine is running, comes to mind.
Old Jul 30, 2018 | 12:50 PM
00pooterSS's Avatar
Check the plug in wire, the exciter wire. May be worth a try to try a new connector.
If that doesn't work sounds like your new alt failed.
By the way check this out, it's a cheap way to have a really good alt
https://ls1tech.com/forums/generatio...failure-s.html
Old Jul 30, 2018 | 01:53 PM
Pimpin' out your secrets, huh Pooter? LOL Couldn't resist... Have a good one!
Old Jul 30, 2018 | 04:39 PM
00pooterSS's Avatar
All good, I'm here to learn and help so when I have the opportunity to help I pimp for free.
Old Jul 30, 2018 | 05:03 PM
I totally agree! Always ready to spread good (hopefully..lol) info to help those needing/wanting it!
Old Jul 31, 2018 | 03:32 PM
curtisad's Avatar
So I talked to Mechman Alternators and they said that since I didn't run a 2 gauge cable from ground back to the alternator I probably fried the diodes in the rectifier. The only thing is, I didn't have a lug for the return ground. They are going to fix/replace it for free so I am happy. I requested that they send me one back with a ground lug.
Old Jul 31, 2018 | 04:04 PM
00pooterSS's Avatar
Yeah that may have done it, big alternator trying to pump out amps and no where for it to go..
Old Aug 1, 2018 | 12:43 PM
chrysler kid's Avatar
I think I went overkill and I have 4 different ground cables added to the corners of the block and on the alternator bracket. I was tracing random misfires and I had relays melting, long story "short" the engine harness had a fray at the alternator excitor wire and the primary oxygen sensor wiring also had a fray and they were just rubbing themselves into arcing
I did 2 gauge wiring for power, and for the fuse supply, and primary ground from the battery to block and chassis. I used the factory ground cable to bolt to the atlernator bracket case and bolted that to the frame rail under the fuse box
I have the 105 amp alternator off of my truck on the Camaro, and a new duralast gold on my truck. The f-body hates the aftermarket voltage regulators or something. I've verified several times that only a GM alternator will cure my check gauges light dimly lit at night. Has to be an OG unit
Old Aug 1, 2018 | 01:03 PM
00pooterSS's Avatar
Yeah you went way overkill lol.
And I agree about the OE alternator thing, that's why I made that alternator thread about using used truck alternators. They were the only ones that acted right. A new dealership or ac delco unit may act right, but when you can get one for $60 vs $300-$400, I'll take the $60 one.
Old Aug 1, 2018 | 06:28 PM
Can you elaborate more on your CEL being lightly lit. I have the same issue, and it’s driving me crazy.
Old Aug 4, 2018 | 12:04 PM
curtisad's Avatar
Mechman Alternators makes a pigtail that you have to connect to a 12 volt keyed source that will make the check gauges light go away. Their phone number is 1-888-mechman.
