Finding leak in AC System..
Old Jul 7, 2004 | 03:15 PM
Z28Venom's Avatar
Default Finding leak in AC System..
Well.. My AC had stop blowing cold, so I bought one the little refill kits at Checkers and charged the system back up..
Well, it's been about 2months and the damn thing isn't chilling again.
When I put my ear near the EVAP canister there seems to be leak down near the AC Compressor. Is there anyway find the leak, or should I just get a new compressor.
I have a pic of my EVAP canister, and it looks nothing like the ones that I've seen on all the other cars. I guess the AC system on my was changed out or something.
I have a few pics that shows my evap canister.. AC Pics
Old Jul 7, 2004 | 04:24 PM
Hardtop00SS's Avatar
they have AC dye, that's sometimes already in the R134 can, that you put in the AC system and you shine a black light on all the AC lines and where the dye is, that's where the leak is. You can also look at all the connections on your AC lines, and where there is usually debris and a slimmy type residue (pag oil usually), then that's where your leak is also.
Old Jul 7, 2004 | 09:26 PM
wrencher's Avatar
wrencher
If you can hear it leaking, try to listen where it is coming from with a hose or something. It could be the compressor itself or the manifold hose assembly.
Old Jul 7, 2004 | 09:44 PM
Z28Venom's Avatar
Do you any of you guys think that the EVAP canister on my car looks odd?
Old Jul 7, 2004 | 10:17 PM
wrencher's Avatar
wrencher
Do you mean your catch can or the accumulator?
Old Jul 8, 2004 | 02:04 AM
Z28Venom's Avatar
Yea.. the canister that right next to the Catch Can. All of the others that I've seen are bigger on the top. Mine looks totally different from all the others.
Old Jul 8, 2004 | 04:27 PM
Do you have a pic of under your hood? The EVAP canister on late model f-bodies are on top of the fuel tank. If your talking about the reciever/drier which is on the passenger side of the engine, that may be bad also.
Old Jul 8, 2004 | 05:27 PM
robertbartsch's Avatar
That big tin can is the AC receiver/drier; I just replaced mine at $75 bucks...
WE NEED A NEW TOPIC ON THIS BOARD THAT DISCUSSES AIR CONDITIONING - PLEASE WRITE YOUR FAVORATE ADMINISTRATOR AND REQUEST THIS SMALL FAVOR....
Old Jul 8, 2004 | 11:04 PM
wrencher's Avatar
wrencher
If it is in the high pressure side it is a reciver-drier. If it is located in the low side it is an accumulator. That's really the only difference between them , most GM cars are accumulator equipt including F-car, just a FYI.
Old Jul 8, 2004 | 11:08 PM
wrencher's Avatar
wrencher
It is different was it replaced at some time? Prolly was there are a few diffent ones, may even be a non-delco piece. It looks like an older LT1 car drier.
