Injectors
Old Sep 6, 2018 | 02:20 AM
Fletcherj1's Avatar
Default Injectors
Hi there,
I have just purchased a high rise, dual throttle body intake to run on my 5.7l ls1. I have two 4150 throttle body's on it, both are 1000cfm. I am stuck on what injectors to run. Is there such thing as too big?
what does everyone recommend?
thanks
Old Sep 6, 2018 | 02:21 AM
Fletcherj1's Avatar
Originally Posted by Fletcherj1
Hi there,
thanks
Old Sep 6, 2018 | 10:26 AM
How is the rest of the motor set up? No matter what, a 346cu in. engine will NEVER EVER use 1000cfm. Why so much?
Old Sep 6, 2018 | 11:27 AM
sjsingle1's Avatar
yes you can be to big ( that's what she said ) ......consult a tuner
Old Sep 6, 2018 | 01:30 PM
8.Lug's Avatar
You spinning to 11 or something? 2,000cfm is a lot of air for a 5.7
Old Sep 6, 2018 | 01:34 PM
I'm not sure he meant both are 1000cfm EACH or in TOTAL. Either way, that's a lot of cfm for a 5.7 to handle.
Old Sep 6, 2018 | 02:11 PM
Fletcherj1's Avatar
That's just the size of the throttle body's that came in the kit I brought. I thought they were 500cfm each, not 1000cfm each. I have this Cam, also I have 3 inch headers and I am in the process of finding the right heads to get as well.
Old Sep 6, 2018 | 02:32 PM
8.Lug's Avatar
Did you just close your eyes and point to something in a catalog? What exactly was your reasoning behind getting this dual intake? You're never gonna get this to run right. Sell that nonsense.
Old Sep 6, 2018 | 02:48 PM
Answer this- WHAT do you want to end up with? WHAT are you going to use it for? Don't just buy a bunch of stuff that you think will look and sound cool. You will be SORELY disappointed...
Old Sep 6, 2018 | 02:59 PM
Darth_V8r's Avatar
Moderator
i'd get 650cc injectors. Talk to Lance at Pantera. Hes a sponsor here.
Old Sep 6, 2018 | 03:53 PM
Full-Force's Avatar
You guys are missing the point here! He got that "(increased overlap) for the big idle sound"! Big idle sound demands big airflow!
Old Sep 6, 2018 | 10:40 PM
Fletcherj1's Avatar
Default Cfm
Everyone is saying that 1000cfm throttle body's are too big. What size does everyone recommend ? Thanks
Old Sep 6, 2018 | 10:57 PM
Why don't you figure out the airflow demands of your engine and see for yourself? It's not hard, and that way you learn...
Old Sep 6, 2018 | 11:57 PM
Fletcherj1's Avatar
I obviously got it to get a lot of air flow. A lot of people are running these intakes here in nz and they run fine. They wouldn't make them if you could never get them to run right 👍
Old Sep 7, 2018 | 12:00 AM
Fletcherj1's Avatar
Not hard with a factory engine but it's abit hard to find out the demands of my engine with the parts I have. That's why I am on here looking for advice, not looking at getting bagged by people.
cheers
Old Sep 7, 2018 | 12:02 AM
Fletcherj1's Avatar
I want a high performance engine. I never brought it for the looks of sound I brought it for the power gains you get over other intakes.
Old Sep 7, 2018 | 12:07 AM
Fletcherj1's Avatar
Old Sep 7, 2018 | 02:41 AM
8.Lug's Avatar
You make too many excuses to do things the wrong way. And show me one single person running this setup on a 5.7.
Old Sep 7, 2018 | 03:02 AM
Fletcherj1's Avatar
This guy is running a Holley high rise dual intake with 2 1450cfm throttle bodies and 1000cc injectors. That good enough for you??
Old Sep 7, 2018 | 07:46 AM
Full-Force's Avatar
These guys in Australia and New Zealand run some crazy setups! They making some big power over there. Everything they do is big. Hell I seen where someone put a top fuel engine in a mustang!
