Intake problem
Old Sep 8, 2018 | 03:13 PM
Jtuck3967's Avatar
Default Intake problem
I have a 99 Trans Am I updated to a Dorman intake. I had to move the MAF sensor to the front. Now it doesn't have the same power as it did. Keeps throwing the TPS sensor code. Is it because it needs a tune or is something wrong here.
Thanks for any help you can give.
Old Sep 8, 2018 | 07:39 PM
The MAF sensor is ALWAYS in the front. Do you mean the MAP sensor?
TPS is Throttle Position Sensor. Broken wire?
Old Sep 8, 2018 | 09:57 PM
big hammer's Avatar
TPS is either effed or not plugged in
Old Sep 8, 2018 | 10:21 PM
Jtuck3967's Avatar
I will get one and try. So the map should be ok relocated.
Old Sep 8, 2018 | 10:35 PM
8.Lug's Avatar
Not really. Should be in the back.
Old Sep 9, 2018 | 09:44 PM
jaxcam02's Avatar
I kept mine in the back. Just drill out the hole and use rear location. Plug the front with the ws6 store plug.
Old Sep 9, 2018 | 11:38 PM
Compsystems's Avatar
post the exact code you are getting.
Old Sep 10, 2018 | 07:07 AM
Jtuck3967's Avatar
p0122
